Sponsored by: CARiD
locker interchangability
Old Feb 28, 2010 | 10:28 PM
bdiz's Avatar
has anyone ever put a v6 locker in a 4 cyl third? is it even possible?
i got a new v6 aussie locker, but i got a good deal on a 4cyl third with 529's that i want to put the locker in.. would it work with some minor fabing or would it be easier to just swap the 4cyl 529's into the v6 third
Old Mar 1, 2010 | 12:04 PM
Matt16's Avatar
Nope, completely different unit, your V6 locker only has half as many parts as the 4 cyl.
Old Mar 1, 2010 | 02:16 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
according to this... if you change your carrier...
"All pre-'95 4-cylinder 4wd mini-trucks & 4Runners use the Toyota 8" 2-pinion differential front and rear (except turbo models). This is known as the "4cyl diff." This diff is by far the most common diff in older Toyotas.
- Ten 10mm ring gear bolts
- 27 spline pinion
- 2-pinion carrier (case)
- V6 carriers can be used in this diff if the correct bearings are used
* LPH/SPH gear info: http://www.pirate4x4.com/forum/showp...3&postcount=73
** 4cyl diffs are swappable with the V6 and high pinion diffs."
Know thy link...
http://home.4x4wire.com/erik/diffs/#rear
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
icentropy
Sep 10, 2015 05:03 AM
