Sponsored by: CARiD
intake for injected 22re
Old Jan 30, 2010 | 04:16 PM
whitenblu yota's Avatar
do i just take off the airbox after the sensors? i got an intake off of a mitsubishi for 5 bucks at a swap meet and the pipe is only like 1 foot long.
Old Jan 30, 2010 | 07:45 PM
myyota's Avatar
If you want to add a high flow air filter you will need to remove the AFM from the stock air box by unbolting it, next you will need an adaptor to bolt on to the AFM that will allow you to put the filter on the AFM, with out the adaptor its not possible to put the filter on.
Old Feb 1, 2010 | 04:22 PM
thanks for your help i ended up moving the maf over, and making an adapter for it.
Old Feb 1, 2010 | 05:13 PM
myyota's Avatar
Its not a maf, its an afm = air flow meter, there is big diference between a maf and a afm.
Old Feb 1, 2010 | 05:27 PM
my bad but i moved it and thanks to you it works great
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
Tacoma1313
Aug 17, 2015 05:44 PM
