Sponsored by: CARiD
carb issues
Old Feb 4, 2010 | 08:58 AM
03_rubicon's Avatar
carb issues
i have 1985 toyota pickup that is a 22r carb motor and i cant get it running agian it was running then i parked it for a couple months till i got my lift and know i cant get it running again if you poor gas in the carb it will run but wont stay running. any ideas would be great thank you
Old Feb 4, 2010 | 09:17 AM
MAINETOY's Avatar
Pull the fuel line off the carb and put the line into a bucket and crank it over to see if fuel is flowing.if not the mechanical fuel pump is junk,or could be out of gas,or a restriction in the fuel line.if it is getting fuel you could have a stuck float in carb.hope this helps.
Old Feb 4, 2010 | 04:11 PM
eddieleephd's Avatar
may need to rebuild the carb fairly easy pull apart replacing parts along the way. Some times this will happen in your situation, once I did a throttle body on a civic and I could not get every thing apart but when I put it back it worked great "couple orings missed" but yeah if it gets gas to the fuel line I would suggest going straight for a rebuild!
bigjstang
Jun 2, 2025 03:56 PM
God's Bounty Hunter
Oct 23, 2015 09:44 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
Yota.Jay
Jul 23, 2015 08:08 PM
