Sponsored by: CARiD
fj80 front axel
Old Feb 26, 2010 | 05:11 PM
mikeycruiser's Avatar
fj80 front axel
does any body know if theres anything else you can add to the front axels if there leaking. Its a pretty big job to repair the seals. I hear you can pack grease in them. They are the ball style joints.
Old Feb 26, 2010 | 06:06 PM
waskillywabbit's Avatar
You replace them.
Old Feb 26, 2010 | 07:55 PM
eddieleephd's Avatar
Originally Posted by waskillywabbit
You replace them.
x2 the effort that you put in to packing them with grease "pulling the axle and reinstalling" Is far more effort to do twice rather than using a screwdriver to get the seals out and using a socket large enough to drive a new one in packed with grease!!!
Old Feb 27, 2010 | 04:13 PM
front axel
you can use a screwdriver to get it out to skip taking the whole hub apart. if so anyone have anymore details.
Old Feb 28, 2010 | 05:50 PM
http://www.ncttora.com/fsm/2000/Repa...0Seal/repl.pdf
this says to drive it out however usually I just use a screw driver "or if you feel better you can buy a seal puller from the auto parts house" and pry it out then use a socket that is as big around as the seal to drive the new one in...
ALWAYS USE GREASE AND DRIVE IT STRAIGHT IN AND NEVER GO TOO FAR JUST FLUSH WITH THE CASE!! insert the axle and put it back together......
88sasturbotoy
Jan 30, 2026 01:57 PM
Numberonedad6
Jul 30, 2015 07:10 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
