Sponsored by: CARiD
Hub Help
Old Feb 15, 2010 | 02:35 PM
langzaiguy's Avatar
Hub Help
I've got an 89 4Runner with a solid axle from an unknown year; the PO put it on. The 4WD works great, but when I have the manual hubs engaged, it has a really difficult time turning. When I disengage the hubs, the truck turns just fine. Anyone have an idea?
Old Feb 15, 2010 | 02:39 PM
toyota4x4907's Avatar
The front differential could have a locker in it. Jack up the front end so both tires are off the ground. Spin one side: if the other side goes in opposite direction, front diff is open; if it goes in the same direction, its locked.
Old Feb 15, 2010 | 02:49 PM
langzaiguy's Avatar
Thanks! That had occurred to me as well. I recently purchased this Runner and this is my first time really using the 4WD.
Old Feb 15, 2010 | 03:38 PM
Marc's Avatar
Are you doing this on pavement or some other high traction surface?
If so, it's normal.
Old Feb 16, 2010 | 12:10 PM
He said when he has the hubs engaged, didnt say anything about being in 4wd.
but yes, if he is in 4wd on dry pavement or high traction surface, this is normal. If only the hubs are engaged, then something else.
Old Feb 16, 2010 | 07:16 PM
langzaiguy's Avatar
Yes--it's when the hubs are locked regardless of 4WD or 2WD. So is the locker theory out then?
Old Feb 16, 2010 | 07:42 PM
4Crawler's Avatar
Easy enough to tell if there is a locker in there. Jack stands under the front axle (tires in the air), lock both hubs and spin one tire and see what the other tire does. If it spins the same direction then there is an automatic locker in there.
ladybugRC
458
Aug 21, 2020 10:41 AM
G-off
Dec 29, 2015 12:44 PM
AaronM
12
Nov 4, 2015 04:06 PM
stanz
Oct 30, 2015 10:33 AM
Toys4parts
Sep 26, 2015 01:56 PM
