Sponsored by: CARiD
91 Pickup- Runs rich when first started.
Old Feb 10, 2010 | 04:52 PM
jayhawker1985's Avatar
I've got a 91 Pickup 4cyl and the thing runs a super high fuel mixture, a high idol, and blows tons of white smoke from the tail pipe when first started.After it warms up a bit, the idol slows down, then speeds up and down again and up again, like the o2 sensor is not really sure what the fuel mix should be. After it is warmed up completely it runs like a dream. Anyone know why this is and if it something I should be overly concerned about? I used carb and choke cleaner on the intake to get some of the gummed up dirt out and lowered the idol screw down so when it is warm it runs smoothly. If I need to idol up and put some dirt back in there, let me know.
Old Feb 21, 2010 | 08:06 AM
yotaneck13's Avatar
idol back up and when it is reving up and down like it does pull your tcase shifter back into 4wd if it stops or slows it verywell may be your tstat is bad and sticking if it doesnt change does it when you apply pressure to the brakes? vaccume leak somewhere if so
young buck
18
Aug 27, 2018 02:40 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
calderp
Jul 27, 2015 09:58 AM
