Sponsored by: CARiD
Ring & Pinion gear ratio?
Old Feb 26, 2010 | 04:00 AM
85build's Avatar
Quick question about gear ratios or those with experience with gearing down the Toyotas. My only exp. with this was on a 68 GMC that I swapped out the front end on and I had to match the gears. That was years ago and a different truck.
So my question is I see basically two gear options for my rig: 4.88's and 5.29's. The 4.88's are recommended for 33's and the 5.29's for taller tires but how much lower of gearing can I expect? I don't mind the lower gearing, I just don't want something that is going to top out at 55 or 60mph due to the gear ratio.
Any suggestions?
Old Feb 26, 2010 | 05:33 AM
mt_goat's Avatar
You are a person of few words.
A. How to determine?
B. How to change?
C. Which ones do I need?
D. None of above?
E. All have been answered already if you search
Welcome to YT
Old Feb 26, 2010 | 05:50 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Any suggestions?
Old Feb 26, 2010 | 05:52 AM
please search for a gear calculator...
http://www.4lo.com/
http://www.rocky-road.com/calculator.html
http://izook.com/gearcalc.htm
http://www.f-body.org/gears/
You also need to know weather you have a AT or not... B/c you use the next lowest gear for the tire diameter you want if you have one.
Old Feb 26, 2010 | 05:54 AM
mt_goat's Avatar
Oh...black letters on a black back ground = invisible
Old Feb 26, 2010 | 05:55 AM
yeah, preview post much?
Old Feb 26, 2010 | 06:39 AM
mt_goat's Avatar
https://www.yotatech.com/forums/f116...osting-204178/
oldirtydirt
Feb 23, 2020 09:30 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
kirkrunner
Jul 27, 2015 07:59 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
