v6 3vze oil pan gasket?
Old 03-03-2010, 04:11 PM
boosted4g63's Avatar
hey guys, im working on a friends auto. v6 3vze 4runner and was wondering Everything i needed to do, so i can drop the pan.?
Old 03-24-2010, 08:54 PM
RobD's Avatar
No, there is no oil pan gasket for the V6. Use Form In Place Gasket (FIPG) material. You can pick it up from a Toyota dealership or use Permatex Right Stuff http://www.permatex.com/products/Aut...sket_Maker.htm
Search on here for dropping the pan. I believe the easiest way is to drop the front diff. I did mine while the engine was out on an engine stand during my swap, so that is a pretty easy way, if you want to go to all the trouble of pulling it.
Old 03-24-2010, 09:08 PM
mrddk92's Avatar
Yeah aside from pulling the engine the only way to get the oil pan off is to drop the diff and that's a pita lol. I had a hard time putting it back in cause I was by myself and only had one small jack lol. If I was to do it again I would just pull the engine and stick it on a stand.
Old 04-01-2010, 12:43 PM
camo31_10.50's Avatar
orrrr you could get a 4"-6" suspension lift so you don't have to do anything but unbolt the pan and pull it out..LMAO totally kidding.
and Copenhagen...you're way that chilton's says is correct
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: v6 3vze oil pan gasket?
