Sponsored by: CARiD
random misfire help!!
Old Feb 16, 2010 | 03:39 PM
sldfrk's Avatar
hey every one. i have a 1987 Toyota 4 runner with a 22re motor. the misfire will get even worse at 3 thousand rpm and up. i have replaced every thing from the rotor to the spark plugs 3 months ago. and i have checked resistance ratings for the coil and pick up coil and i have checked the injectors and cleaned them. i also checked compression on all cylinders they are with in 2 psi of each other. no plugs are fouled they are all the perfect color and i also pulled each plug wire off to see if it would change the idle. also did a fuel pressure test its within specs. so if any one has an idea it would be GREATLY appreciated.
Old Feb 16, 2010 | 05:14 PM
myyota's Avatar
Have you checked the timming ?, and also check for vacuum leaks.
Old Feb 17, 2010 | 06:07 PM
sldfrk's Avatar
timing is good and no vacuum leaks but while i was checking that a friend told me to check my valve springs and they were bad what can you expect with 245 k miles. thanks
Old Feb 18, 2010 | 03:03 PM
madman59's Avatar
Check your injector harness near the EGR valve a friend had a bad missfire/stumble & had it to several shops they cleaned his injectors twice, plugs, cap, rotor & it kept coming back he was thinking possible TPS problem . He brought it to me & I searched the post's here & found one where someone had found the injector harness melted thru where it had been contacting the pipe on the EGR I checked this & sure enough it was rubbing & melted thru repaired it & problem solved. This was on a 89 22re in a pickup.
shooter86314
Jan 7, 2016 07:05 AM
the_supernerd
Oct 1, 2015 09:20 PM
shredder4286
Oct 1, 2015 01:09 PM
Shagool22
Sep 28, 2015 07:53 PM
larrys93pickup
Sep 17, 2015 07:05 PM
