View Full Version : Newbie Tech Section
- Bike rack into spare tire carrier?
- obx header
- newbie with a question 94 4runner
- Changing suspension - no torque wrench?
- Reading Codes
- 90 4runner wont start
- TRD Front Spring Lift
- Bought a 1998 Tacoma, timing chain ?
- Problems with 33s and 3in lift? 3rd gen runner
- tire fitment?
- Welding?
- Shackles
- 94 runner engine swap
- 1994 4x4 PU stopped running
- third member question
- body sway???? question....2wd
- What is this and what does it go to?
- full width axels
- Head Gasket Gone
- will an 89 tercel motor fit my truck
- Parts sites?
- 1986 runner loud knocking...please help a newbie
- Need To Know What these bushings are called.
- power questions
- New to yota tech- just a few questions
- leaf spring info please
- newbie with a clutch question, be gentle haha
- Fuel Pressure? Tranny?
- Engines that fit stock mounts?
- Throttle tight
- 94 v6 transmission cooler?
- new bench seat?
- HEI Distributor for 2F engine
- Forward in Reverse?
- "Hey Corey, where is my thread?"
- connecting rod order on the crankshaft
- Best Winter Tires!
- 96 Tacoma will not start?
- power antenna noise
- Lockers
- rocker arms
- code 52
- 89 runner body lift???
- 86 arb going into a 85 4runner Front
- Supercharger help
- 99 Supercharger problem
- 22re truck won't start. electrical problems?
- Starting SAS on my 86 Runner
- new gear time
- ECM Problem
- how to drop my front differential?
- Shift Lever Cap
- What Lift does my 02 Taco have?
- will a 4-runner v6 lockrite fit 90 p/u 4x4?
- 94 runner backwindow
- Reinstall dash piece after changing shifter seat/bushing...???
- No vacuum TO the Brake Booster
- Gas peddle sticking '03 4Runner
- Body lift. How much is too much?
- Vacuum advance??? Timing
- volant cold air intakes
- what springs do i use????
- Add a leaf spring lift kit... help
- Just rebuilt front end on my 96 4runner
- AFM test question, and fuel pump voltage
- Aftermarket?
- Where can i find a grille emblem?!?!?!?!?
- power power power.....
- I dont know which lift i should go with
- Bump
- I dont know where to start.
- will this rim fit?
- Water coming out my exhaust
- '92 4runner w/ overdrive issues
- one mor ruf ??????
- Shims
- Spring/shackle angle question
- Shackle lift pros and cons
- Tune Up
- water in my oil
- Hi-Lift Custom Mounting
- oil pressure
- Solid axle hunting
- Looking in all the wrong places?
- new kid on the block
- 92 manual hubs
- New guy needs some help
- Help to replace belts
- Couple of quick questions
- Replacing negative battery cable
- 97 tacoma 2.7 snorkel?
- Idler arm replacement questions... wheel bearings too.
- 86 4-runner 22re head replacement
- 1st generation lifting options
- TM 4" Bracket Lift Install - couple questions...
- steering troubleshoot
- Body Lift Question
- Who makes the best replacement ½ shafts?
- lift kit for 81??
- 3.0 swap
- Yet another no spark thread
- Newbie
- tires rubb, what wheel spacers to buy?
- leaking oil on 22re
- 90 4 runner a.d.d hub conversion help
- Fair Price For Timing Belt - Water Pump 2001 Runner??
- Removing a 2nd gen p/u axle...?
- DP Diaphragm Air Filter? Where to buy?
- Lift Block Kit Question
- questions about gearing
- 4 Runner axles
- 3 inch body lift questions
- Rear spoiler for '05 SR5 - OEM or aftermarket?
- Highsteer clearence question
- Airbag Help/ questions
- 1985 toyota leaf spring ?
- Wining noise from rear of truck (its not the wife)
- Sway bar disconnect
- 1980 4spd with 33"... 4.88 or 5.37?
- How to access spark plugs on 95 4Runner
- HREW and DOM
- 2000 celica gt electrical problems.
- How to: Changing fog lamps on 3rd gen stock fogs
- OEM E-Locker
- electric or clutch fan
- Lockers and tire size
- ubolt flip
- Lift for 3rd gen 4runenr
- rear locker and bumper ideas
- rear diff repair ?
- Noob SAS ????
- going trip to Shaver/Huntington Lake CA
- Want to improve brakes, what are the options ?
- puting carb on 22re
- 1993 Toyota PU 22RE Overheating
- body lift ?'s
- Wiring Diagram 22r 84
- FSM - 1986 runner - no luck?
- suspension question!
- Ironman
- Got all my lift parts, have a few questions...
- lift question
- Thinking about a dual T case.. i need some advise
- Lift on a lift
- Hi. I'm new, but not a newb. I've got a weird problem!
- 5" Lift and only 33" Tires?
- better mpg info
- HEAD bolts torquem HOT?
- 1985 Toyota pickup
- 4l60e mounted to toyota T-case fluid
- Beck Arnley parts
- dual cases: Paper or Silicone?
- Hub Question
- bent axle. Which rear ends are interchangable 86 4x4 pickup
- squeeling turning
- Lift Options
- Rear axle swap from an 87 to an 85?
- Who here runs LC rear coils
- adapter plates
- More Q's
- Difference between truck and 4runner bumper
- preventative drivetrain maintenance??
- ? About Faded Spots.
- Question!
- just died on me while driving
- PS Leak, Alternator and AT
- 86 toyota 4x4 22r transmission swap help
- Question bout a 89 ifs
- body lift or shackle?
- Good Replacement shocks? Time to replace?
- third member ribs
- Few issues, any help?
- How do I get the codes out
- Rear defrost
- Newbie'e looking for a FJ60 series
- What year trannie will fit 85 runner
- spark plug wire
- Back spacing question
- SAS, LC Axles on a 4rnr..??
- Adapter for r150 to gear driven tcase?
- Does someone know what this hose is for...VID...
- Safe use of my 4x4
- Diff Size
- New guy again lift questions
- Difference between power steering boxes
- can you change the light color in the 95 sr5 dash cluster?
- 3vze to 22re question
- help understanding gears.....97 4runner
- Need link to tune ups for the novice
- Engine Rebuild...
- Does anyone know of a good high steer install write up?
- what is stock height for 87 4runners
- G52 to W56
- fj40 axels on 85 pickup swap
- I need some mods
- +-4,200 rpm for about 75mph, is this normal?
- Wanting to lift my truck for cheap.
- couple of 22r questions
- someone please confirm this for me
- Dash LED's 1992 Toyota pick up
- how much can i tow in my 99 tacoma 4 cyl. 4x4
- who do you guys recommend for an engine rebuild kit?
- Land Cruiser Coil thread
- Aussie, spool, or open diff for front of 94 IFS truck?
- What axels to buy
- How to fix tires rubbing
- Drain holes in exhaust
- 3.4 ticking sound
- Name this 4runner part!!!
- wheel bearing 89 pu
- Upgrading to 3.4L - what donor do I need?
- 2x4 Low?
- 85 pickup pressure plate torque specs????
- Can someone help me find 16x8 black steel rims with 3.75 or 3.50 bs??
- 95 runner transfercase
- How to pour seafoam into my motor?
- mild lift? opinions
- Zerk Fittings
- PIC request
- Whats The Best Gear-Ratio For Running 35s
- Front & Rear Gears Don't Match?
- increasing spline number
- Which exhaust Kit?
- 33x10.5 4.10
- Front Bumpers for 2002 4runner
- What seats are recommended for my truck?
- taco engine swap
- transmission question?
- Im a Newbie. lol HEAD GASKET...
- luchbox locker for front ifs 7.5
- RMI-25 for our radiator?
- oil pump marks
- noob tire question
- Engine Swaps and prices 91 4Runner
- stock axles with 351 swap
- Will a hitch from a 1995 4runner go on my 1994 pickup.
- 22r to 3.0 swap
- sas driveshaft questions
- Looking for OEM cloth for seats
- (newbie) 94 to 86 diff swap
- rebuild pre lube
- want to swap 3.0 to 4.3
- 87 4X4 PU Head Bolt Issue
- looking for pre 79 window seals
- Timing Chain guides
- Fuel Problem Or??
- 1990 4runner code 52
- 1993 4Runner Lacks Power
- You do you recomend for 22re long block.
