Sponsored by: CARiD
stock axles with 351 swap
Old Dec 28, 2009 | 12:57 PM
kottunmewth's Avatar
Ok,this mite have been addressed but could not find anything when I did my search.I am putting a 351w and AOD in my 79 yoda,not going to build it up just bone stock with a propane kit.I was just looking for good of idle low end torque only a v8 can deliver,and going ford because I like the sound and the way it Idles not to mention I happen to have a 351w sitting in my garage without a home.
The question on my mind is,How long will my stock 4 cyl 3rds last if I dont abuse the truck?What could I do other then replacing the intire axle to make them hold up to the v8?
Exsperiance tells me I will snap the 3rd before the axle or pinion but I was looking for some insight from poeple that have done a v8 that could tell me how long there stock set up lasted.thks in advance.
Your not having fun if you dont break something!!!!!!!
Old Dec 28, 2009 | 01:26 PM
eighty5yota's Avatar
just swap a ford 9" rear.. itll pay off better on the long run.. and you could stomp the skinny pedal when you wanted..
Old Dec 31, 2009 | 12:17 AM
So your saying to put a 9" in the rear,what about the front,do I need to put one up there or does it not matter?
How about this,Can I swap the 3rd member out for a stronger one say like a v6 or swap in a dana 44 3rd.I know it wont bolt up but got a welder and can weld mounting bolts on to match or have a shop do it for me.Any body have a suggestion other then spending 2-4 g on 9" rear and front?
Old Dec 31, 2009 | 12:41 PM
peow130's Avatar
you could try a V6 third.
Alot of guys run V8's through toyota axles without any issues.
also, a 3rd from another axle won't work in a toyota axle, lol.
toyotas are 8" carriers, so putting anything bigger in it would require a larger housing.
Old Dec 31, 2009 | 02:25 PM
maybe a v6 rear axle and a d44 or 60 would manage.. but youd have to be easy on them.. is the windsor built or what?
Old Dec 31, 2009 | 04:13 PM
Its a stock motor rite now,233 hp, I am planning to put propane on it so I am going to build it to propane specs witch includes upping the compression,but my plans are to keep it stock.The power a stock motor puts out is a hell of a lot better then what I can squeeze out of the 20r I have and if I am going to start swapping motors around I am going to do it rite the first time,like I said before I already have the motor in my garage.Its the off idle torque I am going after.Not planning on racing the truck just having fun off roading.
Old Dec 31, 2009 | 04:23 PM
Blue Bowtie's Avatar
There are quite a few 85-95s runnin Small Block chevys through toyota axles with no problems.
Old Dec 31, 2009 | 07:06 PM
I see a lot of v8 conversions,but a lot have changed out there axles.I'm not willing to give up my narrow wheel base.I guess it would depend on how hard I run the truck.I just don't want to buy lockers for my stock axles and then have to replace the axle when I brake it and have to buy another locker for the replacement axle.
Old Jan 13, 2010 | 01:28 AM
So is there anybody running stock axles with a v8 installed in there truck that can give me some incite as to how long or if there axle have held up to the 8 cylinder?
Old Oct 5, 2011 | 09:33 PM
ExB16ner's Avatar
ppl ran it, but snap axles in least desirable places
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
