Sponsored by: CARiD
Fuel Problem Or??
Old Dec 27, 2009 | 01:25 PM
jyama99's Avatar
Fuel Problem Or??
Hi, First off I have a 1991 Toyota 4X4 pick up with the 22RE engine. The problem is the truck will start then after 2 to 5 min it dies. I can hear to fuel pump running than it shuts off. Replace the fuel pump, strainer and the filter. Same problem Starts runs for a few min than fuel pump shuts off truck dies. Thanks
Jerry
Old Dec 27, 2009 | 01:49 PM
4Crawler's Avatar
See if there are any stored trouble codes:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Test the AFM:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
and/or try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Dec 27, 2009 | 11:57 PM
jyama99's Avatar
Still Not Running
Ok, I did some more test and here is the results. Whem I jump the +B & the FP the pump constantly runs and truck runs with no problems. Soon as I remove the wire the pump shuts off and the truck dies. So I went ahead and bought a reman AFM ($280.00). And same problem. So I returned it. Not the fuel pump. Not the AFM. What next. It can't be that hard can it. Any more Advice out there?
Thanks..
Old Dec 28, 2009 | 01:48 AM
4Crawler's Avatar
See the section on the Circuit Opening Relay below:
- http://www.4crawler.com/4x4/CheapTri...ORelayLocation
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
