questions about gearing
looking at running 35 inch tires on a 87 4runner with a upgraded 22re. but dont have enought power with the 33 coopers i have on it now.
what do i need to do to run 35s?
im lifted 7 inches already so have plenty of room along with marlin crawler bumpers and cut out flares.
do i need different gearing? if so which ones?
or do i step up to a dual transfercase?
i run mostly highway so i need the ability to climb up highway hills. but want the abilty to crawl off road
let me know what you think
yea. well i dont have time to sit and search thru millions of posts with everyones thoughts.
so i decided not to go with a strait axle. im still running ifs.
i have 4 inch suspension lift. 3 inch body. with 33 inch coopers
marlin crawler bumpers front and rear. which i plated solid with some diamond plate and will be adding those sometime this week along with 4 hella 500 lights mounted to it.
i dont want to switch to strait axle due to the fact i run a 96 red ford 250 with a custom strait axle and 8 inches of lift. so i want this to be a just for fun rig.
so i wanna run 35s.
will someone explain the difference between the 4.88 gears and 5.29 gears?
mpg wise?
speed wise?
explain the differences please
as is my 5th gear wont climb a hill. it will only cruise. so im down shifting.
so i wanna run 35s.
mpg wise?
speed wise?
I've run both 5.29s and 4.88s w/ 33s on my '85/22RE. Better MPG w/ 5.29s, the 22RE likes to rev higher. But long highway drives were tiring withe engine wound up in the 3300-3500 range all the time. Did climb hills nice. W/ 4.88s, highway revs are in the 2800-3000 range, much more comfortable, quieter and less vibrations. More downshifting, though. And I have run 35s w/ the 4.88s and don't really notice a lot of difference. Don't have a lot of miles on those tires. Other difference is w/ 4.88s, speedo will be dead on w/ 35s, reads about 6% fast w/ 33s. W/ 5.29s and 33s, you be like 13% fast (I ran a speedo calibration box when I had that tire/gear combo).
what do you mean by you ran 35s and didnt notice a difference?
that you didnt notice a power loss between 33 and 35s?
or that the gears didnt make a difference?
also, i need to build a extension for my front bumper before it goes on. but i dont wanna use the cheap ones that came with the body lift.
any ideas for that? there marlin cralwer
i want something strong that can take a hit.
how much does a speedo calibraton box run?
well in all reality..most 35" tires are only about 1" bigger in circumference than a 33" tire..lol
atleast i think?? lmao
i mean..i myself will probably not run 5.29's..i might..but i doubt it..i will find a set of junkyard 4.88's and run em with 35's to see if i like it or not..
i just want the best MPG's possible..with as much power as possible lol
- http://www.4crawler.com/4x4/ForSale/...ets/index.html
35s have a 1" bigger radius and will sit 1" higher than 33s, but the circumference is the distance all the way around the tire and that would differ by a few inches (maybe 4 or so).
I run a 34.9 x 12.4 Baja Claw w/4.88's and 4Crawler is right, the speedo will be right on and the rpms are around what he says. I get about 16 mpgs after intersate driving between 65-75 mph and a days worth of wheelin with family(wife and two kids) and gear inside. The cheapest way(maybe) might be to score a junkyard set instead of buying new gears and master install kits.
XtraCab
Apr 12, 2020 05:25 AM
coffey50
Jul 28, 2015 10:55 AM
Jnkml
Jul 6, 2015 01:20 PM
