Sponsored by: CARiD
transmission question?
Old Dec 29, 2009 | 03:52 PM
ethanp123's Avatar
what is the strongest 5 speed tranny that will work in an 1986 4runner with a 22re?
Old Jan 1, 2010 | 08:38 PM
annoyingrob's Avatar
An R151 out of a turbo pickup. Good luck finding one though. If you can just get a hold of the bellhousing, you can also use an R150 out of a V6 truck.
Are you 2wd, or 4wd? If you're only running 2WD, a late model W58 transmission (I think 89+) out of several RWD Toyota vehicles can also be used. They switched over to using a steel sandwich plate around that time, vs the older aluminum ones. A MKIV N/A Supra W58 has triple cone synchros on all gears if you want to be really fancy. I THINK that the later IS300s also did too.
A W58 can also be modified to work with a 4wd truck with a little bit of work too.
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
