Sponsored by: CARiD
HREW and DOM
Old Jan 10, 2010 | 08:57 AM
vandert's Avatar
HREW and DOM
Which is better?
I've always been led to belive that DOM is more expensive and better but never knew why.
Is HREW strong enough for Rocksliders that are going to be used as a Highlift mounting point?
Just curious cause I have access to a bunch of 1.75'' x.120'' HREW for REALLY cheap and would fab up some sliders from it.
I live in florida so it won't see too many rocks, more like tree's, but I will use it as a jacking point while on trails of that I'm sure.
Old Jan 10, 2010 | 09:07 AM
malteserunner's Avatar
My sliders are DOM, and they work great. If you plan to use a High Lift on them, just make sure you weld in gussets from the tubes to the frame. The only thing I consider a requirement for using DOM, is for building cages. Bumpers and sliders made of HREW hold up well.
Old Jan 10, 2010 | 10:54 AM
VSU_4runnin's Avatar
https://www.yotatech.com/forums/f88/...umpers-119900/
http://www.savageoffroad.biz/2009/06/dom-vs-hrew.html
Old Jan 11, 2010 | 12:47 PM
vandert's Avatar
Tahnks guys, got it now
I'm going to go ahead and build my sliders out of the HREW then
I will overbuild them and of course go off of other people's versions out there
Old Jan 11, 2010 | 06:02 PM
tc's Avatar
tc
HREW has a seam, DOM doesn't. The process used to make DOM results in better material properties.
DOM should be used on any life-critical applications, like a roll cage, but HREW is plenty fine most everywhere else, the exception being times when you need a nice, uniform inside diameter, like suspension links where you need to put in a threaded insert.
Old Jan 11, 2010 | 06:51 PM
RiCh_90-yota's Avatar
Heres a link from marlin http://board.marlincrawler.com/index.php?topic=60158.0
Jun 1, 2021 01:51 PM
traxman25
4x Innovations
104
May 14, 2014 08:55 AM
Shoua
Aug 29, 2007 09:23 PM
weakyota91
Jul 26, 2007 01:43 PM
89-4Runner
Jul 20, 2007 02:12 PM
