Sponsored by: CARiD
Idler arm replacement questions... wheel bearings too.
Old Jan 15, 2010 | 06:04 AM
poynter's Avatar
I am going to replace my idler arm this weekend as well as the front wheel bearings and I have a few ?'s.
Do I need a pickle fork to get the idler arm off or is it just the 4 bolts on the frame and the one that attaches to the steering rod?
I am getting the arm and bushing together.
Can i go in there and swap it out on the ground or do I need to take the load off the wheels or anything? Should I keep the wheel straight when doing it or is there a better option?
I am also going to replace the front wheel bearings.
I will be getting these from oriellys or autozone etc..
I am going to get the bearings, and seals is there anything else I should do while I'm in there? I will get the grease from toyota I guess.
From reading it seems that I dont need a puller for these bearings and that the only special tool I need is a 54mm socket.
Any tips are appreciated. thanks!
Old Jan 15, 2010 | 06:40 AM
MaK92-4RnR's Avatar
I'll be doing my idler arm this weekend as well... the only thing I suggest is buying a truss from NWOR to make it stronger.
http://www.northwestoffroad.com/part...omponents.html
scroll down to the truss.
Old Jan 15, 2010 | 06:54 AM
T4L's Avatar
T4L
It's a tapered stud where the idler arm attaches to the steering rod. I don't know that you will need a pickle fork, but it may make separating that joint easier. You may want to turn the wheel all the way to the right to give yourself more space. This repair would be easier with the wheel off and out of the way.
Old Jan 15, 2010 | 07:27 AM
874runnersr5's Avatar
You will need a pickle fork, i tried to get away without one and just made a trip to my shop after 10 mins.
Old Jan 15, 2010 | 09:19 AM
poynter's Avatar
Yeah I don't care to pick one up just to save myself the trip and add to my tool collection.
Have any idea as to what size? I think they come in a few different sizes.
Old Jan 15, 2010 | 12:18 PM
desertcamper67's Avatar
Usually there are 2 sizes. you want the smaller one.
I always use the pickle fork attachment that goes on an air hammer. Takes about a second or two but you have to have an air compressor.
With the right applied force in the right spot you can get them off with only a hammer. But thats here on the left coast where they don't rust.
Old Jan 15, 2010 | 01:43 PM
poynter's Avatar
I didnt even think of the air hammer. I have one that I've never used.
I picked up a small pickle fork and some grease so I've got everything I need now.
thanks for the info guys.
Old Jan 16, 2010 | 03:34 PM
poynter's Avatar
I got the idler arm replaced today. Had to use the pickle fork for sure. The bearings will have to wait a few days, I am going to have to order a 54mm socket as I cant find one around here anywhere.
Old Jan 16, 2010 | 04:45 PM
just use a chisel, its not the "right" tool but it does work.
Old Jan 16, 2010 | 06:27 PM
poynter's Avatar
It was only 12.99 from northern tool so not a big deal.
Old Jan 17, 2010 | 05:59 PM
tc's Avatar
tc
Neither a chisel nor a pickle fork are technically the "right" tool. Too likely to damage the boot.
A puller like is better:
The great thing is it works for all the steering connections - pitman, idler, tie rods - everything
Old Jan 18, 2010 | 06:15 PM
oh well, my boot is fine... viva la pickle fork
Old Jan 19, 2010 | 03:56 AM
poynter's Avatar
Originally Posted by Gnarly4X
Are you getting new races with those new wheel bearings?
gNARLS.
Yeah I've got the inner and outer bearings and races and the seals.
I wasn't worried about the boot since I was replacing the whole arm and bushing together.
I was going to let my truck sit for the rest of the week but the battery in my car was dead this morning. I gotta get a battery tender hooked up on it. last winter I ended up having to replace the battery after charging it too many times.
Old Jan 19, 2010 | 02:45 PM
But you need different sizes for the different jobs. One puller doesn't do it all. And as stated, if replacing the part with new, who cares about the boot?
Old Jan 19, 2010 | 06:17 PM
tc's Avatar
tc
Which part of this did you not understand?
On our trucks, YES, one puller DOES do it all.
Old Jan 19, 2010 | 06:38 PM
mightymouse's Avatar
I have the same puller and can vouch, it does do it all!
Old Jan 20, 2010 | 10:23 AM
News to me. I am farily certain that the large spread jaws on a puller that will pull a pitman arm will be too wide for tie rod use.
Also watch out that the little point on the pusher stud doesn't go and mash out or mushroom the hollow part of the tie rod. (where the cotter pin goes through).
Hey mightymouse, I went to Lafayette Sr. High over there back in the early 80's. Ballwin was nice back then. Now I hear its a bit ghetto
Old Jan 20, 2010 | 11:16 AM
ghetto is an understatement! nah it's not that bad it's what you make of it. You can probably understand stl. is one of those cities that is great one block and scary as hell the next. I kinda digg pickle forks for a lot of suspension parts when replacing the whole piece but use the puller when i don't want to screw it up. Kinda depends on the job.
Old Jan 20, 2010 | 06:01 PM
tc's Avatar
tc
Same puller fits our pitman arms and tie rods.
My tie rods (Toyota) all have a little divot in the end for the puller point to fit in.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
ptb12
Jul 5, 2015 01:49 PM
