Sponsored by: CARiD
Difference between power steering boxes
Old Jan 2, 2010 | 02:54 PM
strykersd's Avatar
Anyone know the difference between 1986-1988 power steering gearboxes and 1989-1995 gearboxes? The later is obviously bigger, but does it have a different gear ratio?
After stripping my PS gearbox in my 86 4runner on the trail, I swapped in the first gearbox I could find, which was a from a 90s 4runner. It bolted right in.
Old Jan 2, 2010 | 03:01 PM
4banginRunner's Avatar
yes, not a drastic difference but the late style is a "quicker" box
Old Jan 2, 2010 | 03:03 PM
khany2002's Avatar
I believe that the ratios are different -- the later-style boxes are supposed to have a closer (tighter) steering ratio, but I'd wait for someone else to chime in.
I'm glad to hear that the later and earlier styles are interchangeable -- I was going to swap my early-style gearbox for a later one for the closer ratio, and was wondering if it was a simple bolt-up operation. Were there any additional lines you had to cap off, or anything out of the ordinary (perhaps the pitman arm was splined differently, etc.)?
Old Jan 2, 2010 | 03:06 PM
100% interchangeable, nothing capped, remove the old, install the "new"
Old Jan 2, 2010 | 03:17 PM
http://www.pirate4x4.com/forum/showthread.php?t=587515
Old Jan 2, 2010 | 03:57 PM
khany2002's Avatar
Thanks for clarifying; I'd seen that link before when I had to replace my box, and ended up choosing one off an '87, as I wasn't sure about this line:
"The longer input gear is only an issue if you are replacing a box. If you switch from one style to the other you will need to change the length of the steering shaft that goes to the steering wheel."
I definitely wasn't up for that sort of complication, but, if I wouldn't have to toy with any of that, and could get a cheap box, I might give it a shot now!
Thanks again,
Khany2002
Old Jan 12, 2010 | 12:54 AM
strykersd's Avatar
For the record, even thought the newer box has tighter ratios I wish I had the older style box. I had to change the input shaft seal and it is MUCH more difficult on the newer style box. You can change the input shaft seal on the older boxes in a matter of minutes, to change the input shaft seal on the newer boxes require that you take the whole box apart. Just my $.02
Sleaker
Aug 26, 2020 06:03 AM
msane99
Jul 17, 2015 10:13 AM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 8, 2015 12:05 AM
