Sponsored by: CARiD
Want to improve brakes, what are the options ?
Old Jan 8, 2010 | 05:40 AM
patallen's Avatar
I never realy liked the brakes on my 86' truck, even after having it all refreshed from A to Z, new calipers, discs, drums, hoses, MC,...The truck needs a major press on the pedal to stop it. I deleted the rear proportioning valve so all the power is there to the rear drums, it is much better but still far from what i would like.
Is there bolt-ons for theses trucks, what are the top rated pads for theses ? or a 3rd generation calipers with more clamping forces ?,...
thanks.
Old Jan 8, 2010 | 05:48 AM
91diesel's Avatar
use the V6/T-100 front rotors/calipers and it's up in the air about getting the bigger MC or not. I've already got a V6 truck with this and as a further upgrade I'm thinking of getting some late model (96-98 I think will work) rear wheel cylinders which are 1" bore instead of 7/8" like the truck and should provide a little more brake force. You might need the larger MC if you do this. This stuff is the cheap way, there is always rear discs. You'll see a substantial improvement with the V6 rotors and calipers though.
Old Jan 8, 2010 | 05:54 AM
patallen's Avatar
is this a bolt-on affair on the 4x4 hub ? does the disc are realy needed ?
thanks for the reply !!
Old Jan 8, 2010 | 11:04 AM
patallen's Avatar
how come my thread has moved to the newbie section ?
if only newbie watch the newbie section, what its purpose ? how non-newbie will be interested to help...thats not cool.
i am not newbie...altough the question was easy for most of you.
Old Jan 8, 2010 | 11:29 AM
Matt16's Avatar
Based on a rudimentary knowledge of physics, I would have thought the smaller the bore, the more braking force, but with more pedal travel... Big bore= high pedal effort + short pedal travel, small bore = long pedal travel + low pedal effort.
Maybe check out the later model brake booster diameter, the bigger it is, the lower the pedal effort.
Old Jan 8, 2010 | 12:31 PM
patallen's Avatar
you are right, i am used to work on BMW, i have modified several, and i still own 4, one is a race car, i have played a lot with brake bias and know the basicsof brakes.
I dont want to use the 1" bore MC for my pick-up as it will make the pedal harder. I want to increase pad surface or caliper bores, to the detriment of more pedal travel (more fluid to fill them up).
Anyway, now that i know the V6 calipers are bigger, i may go with this set-up.
Old Jan 8, 2010 | 12:36 PM
camo31_10.50's Avatar
upgrade your rear brakes dude!!
convert the rear to Disc's, that'll help a lot.
then convert to the bigger disc's and calipers and MC and booster up front!.
my brakes work just fine..i just wish i had ABS....i don't like to lock up my tires on asphalt i try hard not to, but sometimes ya gotta lol...damn cows
Old Jan 8, 2010 | 01:12 PM
patallen's Avatar
The rear is alredy locking up before the front, i dont want to change the bias too much.
I should have precised that i want to improve on the front only, and reduce overall pedal effort. Converting the rear to disc is costly, this is a utility truck to carry car parts and wood.
Maybe i have shi**ty pads, i would like to know if there is good pads, Hawk does not seem to make some for the 86-89 4 cyl, other pads manufacturer other than raybestos ty ones ?
Old Jan 8, 2010 | 02:43 PM
fooboo's Avatar
how'd you converted?? sick of tired of drums and squeals too much! and SPRINGS TOO!
Old Jan 8, 2010 | 03:08 PM
ToyoTech559's Avatar
http://www.trail-gear.com/brake.html
Old Jan 8, 2010 | 03:35 PM
patallen's Avatar
Originally Posted by ToyoTech559
thanks for that link, very good !!
Old Jan 8, 2010 | 05:07 PM
i have been thinking bout doing the rear disc brake conversion with a larger bore MC.
let me know how the rear goes if you do decide to do it
Old Mar 27, 2010 | 04:27 PM
dfarr67's Avatar
I was hesitant to go to a 'performance' brake company- but the Hawk HPS on my Chevy are the best I've bought- including ceramics. Hot or cold.
Old Aug 10, 2010 | 10:01 AM
abd9810's Avatar
When you increase the bore size pressure goes down and vice versa... you will notice that the brake pedal has a different pivot point to compensate. This is always addressed with musclecars/hotrods that convert from one brake style/system to another. Most stock GM pedals were drilled for 2 pivot locations depending on application
Old Aug 10, 2010 | 02:59 PM
gary_the_4runner's Avatar
locking in the rear, before front? not good... you should get a wilwood manual adjust LSPV. are your front brakes even engaging? could have bad front calipers or brake lines
Flying91
45
Apr 11, 2024 04:39 PM
chukarhunt
Dec 8, 2019 11:39 AM
Yota.Jay
28
Oct 22, 2015 01:08 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
msane99
Jul 17, 2015 10:13 AM
