Sponsored by: CARiD
power power power.....
Old Jan 19, 2010 | 07:35 PM
senior2010's Avatar
Unhappy power power power.....
Im goin to be honest im not a tech goo roo at all this power building and i know that there are people on this website just looking for easy to understand and straight forward answer or opinion...
i am fixing to put another 3.0 in my 92 4x4 all i want to know is what are some good performance parts that i could install...such as cams,cranks,air intake,headers anything like that...
Thank yall for everything
Old Jan 19, 2010 | 07:38 PM
Birdbrain's Avatar
its really easy, while you replace the 3.0, you add another .4 litres.... LOL
Old Jan 19, 2010 | 07:41 PM
Tracey98277's Avatar
crower cam regrinds
doug thorley headers
cold air intake
fuel chiller (cold can)
port/polish heads
nitrous...
the 3.slows are called 3.slows for a reason, my sincere advice is swap in another motor. there is the toyota 3.4, chevy 4.3, lexus 4.0, chevy 5.7... lots of motors fit in a toyota with some modification.
Old Jan 19, 2010 | 07:43 PM
take a look at my motor
https://www.yotatech.com/forums/f108...ula-ca-201882/
Old Jan 19, 2010 | 07:46 PM
RobD's Avatar
There are those who will tell you that you can't get power out of a 3.0.
You can, but the amount of work and $ involved won't net you much in the way of meaningful gains.
If you can do the work yourself or with help from a friend or two, and if you don't mind tackling some wiring, then the 3.4 swap is a better bet.
Old Jan 19, 2010 | 07:49 PM
bottles's Avatar
there right 3.slow
Old Jan 19, 2010 | 08:09 PM
senior2010's Avatar
ive hought about doin the 3.4 swap but im not the greatest at wiring in fact im horrible at it, if i had sometyhing to help me then y ai would def switch to a 3.4
tracey, man ive looked all over for a cold air intake for one and i cant find one. i have no idea what fuel chiller is. and ive got a question for ya if i got cam regrinds to 264's or 272's would i have to get new heads or get head work done?
and once again thank yall for all the advice keep it comin
Old Jan 19, 2010 | 08:14 PM
well let me rephrase that, *short ram intake by spectre, or... K&N makes a cold air for 4runners but its expensive. fuel chillers or 'cold cans' are devices where the fuel runs through a cooling element (like a mini freon system) and chills the fuel to drop mixture temps and get you some more power and fuel efficiency, they are hard to find. cams... i have the 264's and they are good but i think i should have gone to 272's. and having the head work done is usually cheaper than new heads. mine were about $400. with new valve shims it came out to $500.
Old Jan 19, 2010 | 08:17 PM
senior2010's Avatar
Sweet! aight and what about the cams?
Old Jan 19, 2010 | 08:19 PM
senior2010's Avatar
does anybody got anything on the wiring for the 3.4 swap?
Old Jan 19, 2010 | 08:31 PM
cams are $200 from crower in san diego.
Old Jan 19, 2010 | 08:35 PM
senior2010's Avatar
am i goin to have to buy new heads for me to run those cams?
Old Jan 19, 2010 | 08:40 PM
nope, just have the machinist throw them in to check the shim clearances. crower cut my base circles too small so i had to get all new shims from toyota.
Old Jan 20, 2010 | 05:38 PM
senior2010's Avatar
SWEET!!! lol savin money and gaining power gotta love it
thanks to evrybody that posted and added your 2 cents
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
