Sponsored by: CARiD
What axels to buy
Old Dec 31, 2009 | 03:05 PM
CitrusTheDragon's Avatar
Question What axels to buy
I am looking to go wider then the stock yota axles but I don't know what my options are. I know I have to do something with my front end soon or I am going to lose it. So a SAS is the way to go. I want to stay with a 6-lug but as much advice as I can get would help.
Oh and happy new year
Old Dec 31, 2009 | 05:44 PM
ffryno13's Avatar
well you can do 1 tons out of a fj or get them out off a chevy. what are you going for here? and dont forget to search
Old Dec 31, 2009 | 05:52 PM
Looking 6 to 12 inches wider front and rear. Tubing to run 35s to 37s maybe 40s. SAS with 6.5 lift all around
Old Jan 1, 2010 | 08:32 AM
ScottyC's Avatar
FJ60 axle with wheel spacers will allow you to stick Toyota. Or, you can go FJ80, but the highsteer is stupid expensive.
Or, you can go full width D60s or custom. The world is your oyster.
What is your budget?
Old Jan 1, 2010 | 10:57 AM
For a budget I really don't know what I will be spending. I wanna stay inexpensive as I can but get a good product and end result. It will also need to be able to stand up to a little more horse then the stock 22re (planning a motor swap later). I am also have access to a fab shop style garage, so junk yard finds wouldn't be a bad thing
Old Jan 1, 2010 | 11:42 AM
ScottyC's Avatar
Going 1 tons is a huge commitment. Typical D60 front is $1000 and then you will need to gear it, lock it, etc.
You'll need to run a fullwidth spring hanger and outboard your shackle hangers. This will be the rule of thumb for anything that isn't a Toyota based axle. You really need to start searching threads for what you want.
The FJ60 axle is wider than the mini truck axle by 4.5". With 1.5" spacers or an IFS Hub swap you would be around 63". Its a 9.5" ring gear too.
Old Jan 1, 2010 | 03:07 PM
How do I match the rears to the front? and how wide is stock ifs mini truck axels
Old Jan 1, 2010 | 03:25 PM
FJ-60 axles are 61.5 inches, with a IFS hub swap and 1.5 spacers in the rear I will be a 63 inches. Stock IFS rears are 58 inches which will give me 5 inches wider track, along with keeping the stock 6-lug. Now where do I find Land Cruiser parts
Old Jan 1, 2010 | 03:27 PM
waskillywabbit's Avatar
HERE
Old Jan 1, 2010 | 05:15 PM
g_cali's Avatar
I'd say get on craigslist an see if you can't find some 1 ton chevy's for cheap.
Old Jan 3, 2010 | 06:23 PM
I am going with FJ-60 or FJ-80 same size
Old Jan 3, 2010 | 06:55 PM
AxleIke's Avatar
Fj80 has a small front diff (8"). FJ-60 is stronger. Both rears are offset, and going to be a pain to manage drive shaft angles with out retubing.
Neither one is 6-12" wider. Gotta go full width or custom for those numbers.
With your requirements, keeping this "inexpensive" is going to be silly.
Old Jan 3, 2010 | 06:58 PM
bigarms23's Avatar
go with a passenger side drop dana 44 you can find one on cl for $100 and its already a 6lug
Old Jul 6, 2010 | 04:20 PM
Wow weird starting back up an old thread but it's mine so I guess I can do that. Ok here goes I am ordering custom axles 9.5 toyota ring gears LSD. I am at IFS and was wondering if anyone can tell me what the offset is of the front diff. I am going to search right now but I thought I would post here to see about a quick answer
Old Jul 6, 2010 | 05:00 PM
I need the offset so I can run numbers to make my tubes match up when I start the build. Search didn't turn anything up that I was looking for maybe I worded it wrong
Redeth005
Jun 28, 2018 08:16 PM
Kylenicoll33
Sep 24, 2015 12:13 AM
user 82300
Sep 15, 2015 05:49 AM
chuckd83
Sep 14, 2015 03:20 PM
MudDr
Sep 12, 2015 01:47 AM
