RMI-25 for our radiator?
What is it?
Long story, short - DO NOT ADD ANYTHING BUT DISTILLED WATER TO THE "LONG LIFE" COOLANTS. The Toyota red seems to be a bit more forgiving than Dexcool and the others, but they are still WAY more sensitive than good ole' green coolant.
IMHO, flushing the cooling system every couple years is a fine price to pay to not have all the cooling system issues I have experienced with the Impala running Dexcool (basically, the ENTIRE cooling system has had to be replaced due to Dexcool gelling up)
http://www.rmidepot.com/
reason is i got myself a 4 cylinder and when i opened up the radiator cap it was brown with brown goo around the radiator and the overflow. still bought it since is was pretty cheap. then found out about rmi-25.
what do you think now after the link? thanks
I don't see anything about compatibility with OAT based coolants, but it does say it has it's own corrosion preventive package in it, so no way would I use it with Toyota red based on what I've seen so far.
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
