Sponsored by: CARiD
How to fix tires rubbing
Old Dec 31, 2009 | 02:40 PM
redrider218's Avatar
So im kind of stuck on what to do with my front tires rubbing against the pinch weld every time i turn. Here are my options. 1 to 2 inch body lift and hope it raises it high enough to stop the rubbbing. Crank the tbars untill it stops rubbing. or pound down the pinch weld which i really dont want to ruin the truck by doin this its more of a last resort type of thing. What direction should i go in?
Old Dec 31, 2009 | 02:41 PM
Mic09dcsm's Avatar
beating the pinch weld isn't ruining the truck, the pinch weld is ruining your tires, you have it backwards man
Old Dec 31, 2009 | 02:45 PM
4Crawler's Avatar
Pinch weld trimming is all hidden behind the wheel well liner:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Jan 1, 2010 | 12:26 AM
STEVE_R's Avatar
exactly! beat the pinch weld!!! lol! or just do what i would have done and break out the angle grinder!!!
Old Jan 1, 2010 | 12:36 AM
abecedarian's Avatar
The first problem I see is using BJ spacers and larger tires together. BJ spacers will lift the truck but they don't keep the suspension from compressing the same as it would without the spacers. I.e.: if a certain size tire would rub without spacers, they can and likely will rub with spacers.
Pounding the pinch weld is an irreversable action taken to fix a reversible problem. If you take care and do it right, it is also the cheapest solution to the rubbing problem... provided it gives you enough clearance... and is suggested as a solution for ~31" tires on vehicles not originally equipped from the dealer with 31's. Given you have 33's, I don't think it would be enough unless you can pound over an inch out of the welds.
Were it my truck, I'd body lift it.
Old Jan 1, 2010 | 01:09 AM
Green_slime's Avatar
im with abe body lift is the way to go first and see if that helps or go with some 33 10.5s instead of 12.5s
Flying91
45
Apr 11, 2024 04:39 PM
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
edoyle12
11
Mar 20, 2017 02:26 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
