PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. What brand of exhaust systems should i get?
  2. who else has xtra gauges
  3. 1990 Toyota pickup mod suggestions
  4. starter solenoid
  5. winch question
  6. Regearing just the rear
  7. little u shaped hose leaking
  8. Donate Your DUAL Battery Knoweldge Here
  9. 22re head on 22r block?
  10. sould I upgrade to a IFS rear end and spacers on the front
  11. w56 question
  12. Will 2005 Tundra Access Cab coils (non TRD) fit on the rear of a '95 4Runner 4WD?
  13. what mods should i do to my pickup?
  14. E-Locker Complete Axle Swap?
  15. 94 pickup newb questions
  16. dif breather tip snapped off on my 89
  17. Shocks or Struts
  18. 83 Fj60 backfires, diesels and idles low suddenly
  19. Speedometer going crazy and AC dripping in cabin?
  20. Did Tokico Trekmasters Just Lower my Truck?
  21. Toyota corolla 4AF (sorry about the off-truck topic but I have a 22r as well)
  22. my yota died need help -High Milage 85 22R
  23. New Member with CB install questions
  24. Leather replacement 93 4runner?
  25. what is this from? (differential)
  26. How long to make shackles
  27. Creaking/Squeaking in front left side.
  28. 1st Gen Lock front or rear?
  29. Snorkel for '86 Turbo Toyota
  30. URD vs. TRD Superchargers
  31. Snorkels for the '96 4runner
  32. dual t cases
  33. 22re Overheating
  34. Replaced Clutch Hydraulics and....
  35. Bad oil leak
  36. PCV Valve change on a 3VZE (3.0) V6
  37. What did I do wrong?
  38. Throttle doesnt always respond.
  39. wheel alignment HELP
  40. Adjustable shocks or running different shocks front and rear
  41. turboing my 22re any suggestions
  42. Fuel line repair/replacement advice
  43. 2" lift on 94 4runner
  44. cracks in 3.0 heads
  45. Opps! - lifted and didn't realize it!
  46. Caliper type on 1986 pickup 22RE
  47. What model and year 4 Runners came with E-locker?
  48. coils spacers or coils?
  49. in need of some new tires
  50. Stupid lift idea. Opinions needed!
  51. off road exhaust
  52. converting an 84 to a runner need ideas
  53. 1990 4x4 pickup 80amp Alt fuse
  54. Clutch squeek after wash.
  55. Cold Air intake help
  56. TRD axle swap into 82 pickup
  57. Manual or automatic?
  58. Odd Throttle Response Issue
  59. stuck hood 94 pickup
  60. 1" diff drop with skid plate
  61. Parking Light Circut
  62. '04 Tacoma V6 5VZ-FE Timing belt replacement help
  63. (Small) Giant Sucking Sound
  64. will 2006 4x4 taco front strut assembly (including coil) fit a 1999 4x4 taco?
  65. my first engine rebuild any thing i should know?
  66. No engine lift how do i pull my 22re
  67. 22r no clutch pressure, clutch pedal flat
  68. '86 SR5 4X4 Pick-up Drive Shaft
  69. what type of shocks should i purcheas
  70. clutch question????
  71. (1) U-Joints and (2) Brakes
  72. Run,dead stop,Run??
  73. Is Supercharging a 3VZE a good idea?
  74. just purchased new 33's
  75. Airbags in my coils Need alot of help
  76. removing the side skirts on removable top!
  77. Skid plate bolt size 95 4runner
  78. Stupid Tool Question
  79. Battery or Alternator?
  80. How hard is it to remove a body lift kit?
  81. Fuel pump wiring problem
  82. Swamped Toyota
  83. Speedometer gears not turning.
  84. New truck...what should i replace..pluges wires etc?
  85. valve adjustment worries
  86. Which Headgasket is best and why?
  87. 4runner body on standard cab frame :P
  88. Need Carb Help
  89. Thoughs on OME + Spacer
  90. AISIN IFS manual hub question
  91. changed to bigger tires now truck squeaks
  92. 4runner trans stuck in p
  93. 4runner rear axle
  94. low oil pressure
  95. 4runner to Pickup starter Compatibility
  96. Tacoma ELocker 3RD member Rebuild help
  97. Need Shock info
  98. How are you guys mounting ur tow points
  99. V8 Engine Problems
  100. R&P contact
  101. body lift question
  102. EWeezyota4's question about Front Diff
  103. Help! Front windows don't work in '86 Runner...
  104. Battery Wont Hold Charge- 92 4runner
  105. Rear Brakes
  106. Brakes causing rough idle
  107. 4x4 help on 4runner!!!
  108. Got a 4 wheel drive question
  109. Torsion Bars.
  110. 93 tacoma code 25
  111. Home made body lift?
  112. Self made BJ spacers?
  113. Please Help. broken differential
  114. 3in ifs lift
  115. 22re exhaust pipe bolts?
  116. Are 3.4 tacoma springs stiffer than 2.7?
  117. negitave camber any help/ideas? please!!
  118. Suspension Quote 4Runner
  119. 1999 4Runner Limited Windshield seal
  120. is there a button to roll the rear window? 1st gen
  121. Tire Help...
  122. Where is the dome light wire?
  123. 22rte oil requirements?
  124. BishopLevi '85 4x4pu questions on engine rebuild
  125. Any Off Road DVD films ???
  126. temp gauge spiking
  127. what would be the best engine for my 81 4X4
  128. Why no support for '95 Tacos?
  129. Ex- cab body on single cab frame?
  130. Is the 3vze good for offroading?
  131. Is there supposed to be fluid in the power brake booster?
  132. rough country springs with all pro hangers?
  133. TJM T-15 Bar for different model years the same width?
  134. reduction box housing help
  135. Wanting to fit 35's on 95 runner
  136. Rear brake problem.
  137. 1991 SR5 4x4 Binding in turns
  138. Vacuum and emissions 20r to 22r
  139. Big lift with busted CV - Need help
  140. 90 4runner AC swap into 92 pickup wiring wrong help
  141. Need Help! - Body Lift Gone Bad
  142. 89' pickup w/ 22RE rough idle
  143. 16" wheel backspacing question.
  144. Where to get R-12 Refridgerent???
  145. Possible rear end noise, via high pitched whine
  146. 85' Pickup, Where to start???
  147. Is this hose necessary?
  148. Will a 2010 4runner rims fit a 3rd gen (96-02)
  149. Front diff maintenance and gearing questions
  150. What would cause fuel line to be clogged going into TB
  151. Oil pan removal 3VZ
  152. Novice questions
  153. Does it matter what year?
  154. Mystery Suspension problems
  155. Restart problem with 22ret engine
  156. 3.0L toyota idle issue
  157. 1989 4runner pull codes need help!!!
  158. 82 Supra AFM on a 89 22re
  159. Rear turn signal not working.
  160. Noob Fuel Filler Neck Replacement
  161. dropping in a new engine
  162. Red Paint Fading
  163. What will these repairs cost?
  164. Newbie facing freeze plug replacement 3VZE
  165. What oil weight?
  166. Electricty hates my truck
  167. Rough Ride 99
  168. Check engine light question
  169. stalling 82 toyota truck
  170. Turbo gears in a 22RE ???
  171. Manual hubs?
  172. 82 w/sbc axle question
  173. Transmission Problem after ATF and filter change! Need diagnosis.
  174. What thermostat??
  175. 94 4runner fuse box issue
  176. Dexron III vs IV
  177. Can't Remove Dashboard Trim Panel
  178. Tail Light Needed 96 4Runner
  179. Seized Brake?
  180. Newer Bumper on an Older 4Runner
  181. Looking for cams
  182. 2-3 key turns before starting?
  183. dual cases??
  184. 2.7 3RZ spark knock
  185. Got my New toyota
  186. Why did Toyota...?
  187. Newbie needs help
  188. No morning start?? All lights working.
  189. Anti-freeze for 86??
  190. moving axle forward on '86 SAS'd 4runner
  191. Overheating problem that is making me crazy~!!
  192. Location of coolant drain plug on 3RZ FE engine block 95 Tacoma
  193. clicking when turn the key over
  194. rear shocks with 890 springs
  195. conventional oil vs High End Oil?
  196. Marlin crawler rear bumper.
  197. what came on TRD
  198. No dash lights???
  199. wont start just clicks
  200. I have lift coils, do I need new upper control arms?
  201. coil spring spacers question....
  202. Level Sitting Rig
  203. Newbie Help for 98 Taco lift
  204. 87 cab on 82ish frame
  205. 86 toyota w/marine battery???
  206. Dual case & center console?
  207. gen 1 doubler transfer case
  208. grill for mud truck
  209. Factory 4.88's
  210. Will an V6 3rd member fit in a 4cyl. housing?
  211. Opinions on 22RE ECU
  212. need help! wanting to run 44in tires
  213. 2003 bumper
  214. How do you remove side gear shaft from ifs diff?
  215. Air/Fuel Sensor
  216. rear wiper
  217. need to find a belly pan skid plate
  218. Air cleaner housing quandry
  219. what do i have and what can i do?
  220. Newbie needing more help...
  221. hell bent steel leveling kit for '10 taco
  222. Clearance-wise what magnaflow size is best?
  223. best lift for 1st gen toyota
  224. general question about brakes
  225. Stupid Starter :)
  226. plate front bumper 1st gen Runner
  227. axle swap
  228. Anyone ever painted Factory rims?
  229. Use Toyota FIPG black on your oil pan
  230. My timing was off
  231. starting issues with my 22re moter
  232. Low/Rough Idle after oil change.
  233. 22RE vs. 3VZ-E
  234. Pickup tranny oil??
  235. some 00 runners better than others?
  236. clunking noise from right hub
  237. Replacing Diff and Transfer Case oil
  238. 1st timer need some assistance
  239. sediment in t-case oil--bad news?
  240. 85 22R emission diagram
  241. 2010 2wd taco tires?
  242. Advice on removing a body lift or lowering my truck
  243. 1981 toyota 4x4 leafspring separarted from frame HELP!!
  244. 86 runners rear end going crazy PLEASE HELP
  245. stalling? please help
  246. let's play name these bolts!
  247. Multiple cracks to start in the morning 87 22re SR5
  248. 1987 22RE Temp Sensor, Sensor Switch Problems
  249. how to tell year
  250. ordered a new rebuilt engine.
