Sponsored by: CARiD
Odd Throttle Response Issue
Old Aug 14, 2010 | 12:47 PM
Cookie Monster's Avatar
Hello, i have a 94 p/u with the ol' 22re and i am having some issues with acceleration...
When i first start the truck its all good. After 1-2 minutes of driving i am getting a bit of lag on the acceleration... However if i put the petal to the metal it seems to be fine...
It is most noticeable on the highway... Unless i have the pedal to the floor i cant seem to even do the speed limit! It seems like there is a hesitation and as soon as i push the pedal down far enough there is a lurch and i am accelerating again...
I thought it may be an ignition problem so i changed the ignition coil, plugs, and plug wires. The distributor cap looked brand new so i didnt change that. But no difference
I thought of checking the fuel filter but it appears as if i don't have one!
I recently bought the truck from a guy who had rebuilt the engine 50,000k ago maybe he didn't put a filter back in? Possibly the injectors?
I have been beating my head against a wall trying to think on what it may be... Possibly a timing issue? Or Fuel delivery... I have no idea, and im not very familiar with the engine so any help would be much appreciated!
Old Aug 14, 2010 | 01:18 PM
TOYOTA 1's Avatar
yea you have a filter, its on the passenger side of the block under the intake.
is the check engine light on? sounds like a bad o2 sensor.
Old Aug 14, 2010 | 01:44 PM
myyota's Avatar
Pull the throttle body off and clean it, also check the TPS, sometimes they can go bad and develop a flat spot and cause the problem your having, if its the original TPS with a lot of miles on it, it could just be worn out. And as said above, the fuel filter is under the intake.
Old Aug 14, 2010 | 01:56 PM
Its not throwing any codes, so i will check the tps and look for my filter. Thanks boys. I will get back to ya when i know!
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
rbh261
Jul 13, 2015 12:04 PM
smiley52
Jul 11, 2015 05:16 AM
