Sponsored by: CARiD
Parking Light Circut
Old Aug 14, 2010 | 11:03 AM
whutface's Avatar
So me being a super genius I put 12v to the ground side wire that goes to the switch,
This caused the tail light fuse to blow immediately when turning on the parking lights,
While inspecting I removed the tail light relay and put it back in, Than everything was working fine.
On my way to work later that night the fuse blows again,
I replaced the relay thinking that I melted some wire in the relay causing it to short, And that did not fix the problem, The fuse still keeps popping.
Other than following the wires back to the lights what else should I check? From looking at the book it looks like all there is on that circut is the switch the relay and the lights..
Old Aug 15, 2010 | 11:43 AM
myyota's Avatar
Did you use a new relay ?, this is a long shot, but maybe it some how damaged the switch ?, i wouldn`t think that it would, but stranger things have happened.
Old Aug 15, 2010 | 12:14 PM
swampfox's Avatar
you might unplug the headlight switch and see if it pops the fuse. that might narrow the problem down. if it still pops the fuse start pulling one fuse at a time. this could use a lot of fuses so if you have a 12v breaker of the same amperage, you can wire it up as a substitute for the fuse. this is how i traced a similar problem on a tractor . a good wiring diagram will help a lot.
Old Aug 16, 2010 | 05:49 PM
whutface's Avatar
I got a new relay and that didn't solve the problem so I unplugged the harness from the switches and grounded the light switch wire from the other side and it worked fine so I'm pretty sure its the switch.
Old Aug 17, 2010 | 07:45 AM
swampfox's Avatar
before you buy a new switch try taking it apart, it might be repairable.
Old Aug 17, 2010 | 05:58 PM
whutface's Avatar
Got it all apart and got everything working properly
Now the horn doesn't work lol, I can hear the relay clickin when i push it but no honkin
Old Aug 18, 2010 | 05:08 PM
swampfox's Avatar
glad you got it fixed . sounds like you have one those creeping gremlins that moves around to keep you busy. lol
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
AkitaDog
Sep 1, 2015 08:05 AM
trucker trash
Jul 28, 2015 10:09 AM
CanRunner
Jul 20, 2015 01:29 PM
