Sponsored by: CARiD
R&P contact
Old Aug 9, 2010 | 05:27 PM
brandon0982's Avatar
R&P contact
Hi everyone. I have a 93 2wd yota pickup, I've had a lockright in it for 2 years and now am putting a yukon 4.56 ring and pinion in, I am unsure of the pattern, how does this look?
Old Aug 9, 2010 | 05:29 PM
I just used the factory spacer in that pic. I ordered a shim kit, but hopefully someone can tell me whether I really need it or not. backlash is .0066 there, with the backlash at .0051 (minimum spec) the drive side contact was even farther inboard of the ring gear.
Old Aug 9, 2010 | 05:49 PM
scuba's Avatar
Check Gearinstalls.com and Yukon gear website. You'll find pictures and info of gear patterns there.
I'm no expert, but it looks like a great pattern.
Old Aug 9, 2010 | 05:53 PM
Tofer's Avatar
Sponsor
x2...
Old Aug 9, 2010 | 06:02 PM
BigBluePile's Avatar
ah dude, that looks awesome!x3
Old Aug 10, 2010 | 08:40 PM
Okay, I got it set up today and got the a better pattern than the pic by setting it to .008 backlash instead, the yukon manual says .006-.010 which is more than the fsm reccomends.
except... It is really hard to turn the ring gear/carrier within the lash, is that normal for new, un-lubed bearings and gears?
Old Aug 10, 2010 | 09:04 PM
To answer my own question, I found on ZUK's page on carrier bearing preloadthat 17 in/lbs is okay, I estimate mine at around that.
Old Aug 11, 2010 | 10:47 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
holy carp, x4....
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
live4soccer7
May 11, 2016 06:52 PM
Firefightersink15
Nov 23, 2015 10:32 PM
jacked_72
Sep 14, 2015 03:31 PM
moparbay
Sep 3, 2015 12:48 PM
