Sponsored by: CARiD
What will these repairs cost?
Old Jul 30, 2010 | 06:34 PM
JDS1992's Avatar
I was jus wondering if someone could give me an estimate on a few things that I need done to my 92 4Runner
1. A/C recharge/covert to R134a
2. BFG All Terrains, stock no lift.
3. Serpentine Belts
4. Timing Belt/ Water Pump replacement
-Thanks
Old Jul 30, 2010 | 07:18 PM
Tubbyfatty's Avatar
Belts you can do yourself, search on here, same with the timing belt and water pump if you have some knowlege.
Tires are gonna be like $150-$200 a piece so there ya go.
AC recharge could be around 100 or so, not really sure.
Old Jul 30, 2010 | 08:58 PM
BigSwole's Avatar
a recharge aint much you can do that yourself...converting it over is where the moneys going to be at...
check craigslist for tires...
Old Jul 30, 2010 | 09:04 PM
MaK92-4RnR's Avatar
are you doing this yourself or having a mechanic do it?
1) not sure on the recharge mechanic wise but you can easily do that yourself, converting it will be what costs.
2) my 33x10.50 km2s were 806.50 with a 100 dollar rebate... i believe BFG had a $60 rebate going on right now. so... go get some quotes.
3) driving belts are pretty straight forward and simple, but if you're gonna have a mechanic do your timing belt, might as well add the driving belts into it
4) mechanic - 5-700 dollars for a 3vz.
Old Jul 31, 2010 | 02:17 AM
JDS1992's Avatar
I was going to have a mechanic to do most of it..I can replace the serpentine belts myself but your right when im going to replace the timing belt, i might as well get the drive belts out of the way..
-Thanks for the feedback.
Old Jul 31, 2010 | 06:50 PM
JDS1992's Avatar
im thinking about getting a 2" lift just so there is a noticable difference what should I do, 1" body 1" suspension lift, 2" body lift or 2" suspension lift? any ideas on what would look cool?
-Thanks
Old Jul 31, 2010 | 07:01 PM
dropzone's Avatar
Fossilized
Lift options: search for the ifs lift sticky either at the top of this folder or the 86-95 folder
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
primordialbeast117
Dec 19, 2015 12:23 PM
puddlepirate
Sep 29, 2015 08:02 PM
Project90
Sep 24, 2015 11:40 PM
