sediment in t-case oil--bad news?
I just changed out the gear oil in my tranny and t-case. As it was pouring out of the t-case, I noticed a lot of metal flakes. In the bottom of the catch pan there are a lot of shiny metal bits. I have no idea why there would be so much deposit in there since it doesn't get used but maybe 10 - 30 miles a month. The only thing I could guess at is that it hadn't been changed in a long time (like maybe ever). The question is, how much sediment should I expect and when should I be getting alarmed? Change again in a couple months and see if it's the same or start to worry now?
Is the t-case still working ok ?, If its not making any strange noises and its not poping out of gear, then i wouldn`t worry about it. Its possible that the oil has never been changed before. Change the oil again in a few months and see how it looks.
I haven't noticed it acting strange. I should have mentioned that I bought it with 119k and it now has 142k. It hasn't had the gear oil changed since I bought it. I was assuming that, since it came from a dealer's lot, they would have changed the oil. In fact, I know they changed it in the diffs because I could see some spillage from the fill plug. I just thought they would have done all the oil, but maybe not in the t-case for some reason.
I'll check it again in a few months. Gear oil for the t-case is cheap.
Just because you see oil around the diff fill plug, don`t assume that the dealer changed the diff oil, all the probably did was just top it off. It would be a good idea if you went ahead and changed it your self, that way you know its been done.
JookUpVandetti
Sep 30, 2015 08:58 AM
