Sponsored by: CARiD
what would be the best engine for my 81 4X4
Old Aug 4, 2010 | 07:29 PM
Imjosiah's Avatar
Cool what would be the best engine for my 81 4X4
i just got an 81 that i wan't to start building up. I don't know a lot at all about working on trucks at all. but i do know the old motor is worn, i have to turn up the cardorator a little start it and let it run for a bit then turn it down.....
i wan't to be able to just fire it up and not worry about the motor.
so just wondering what is a good toyota motor, i wan't to be able to do a little crawling.
and what would i all have to change?
roughly what $$ you think?
any info would help
Old Aug 5, 2010 | 08:39 AM
1981 yota's Avatar
if you want gas milage go with the 22r or the 22re
Old Aug 10, 2010 | 02:40 PM
brian2sun's Avatar
That's a broad question and "what you would all have to change" depends on what engine you get and what engine you have now. A 20R to a 22R/22RE conversion should be pretty straight forward. If you're looking to do a Chevy 350 V8 swap then you're looking at a bit more work. Maybe try and post this kind of question in the section called "Engine Swaps": https://www.yotatech.com/forums/f158/
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
garagespace
Jul 9, 2015 08:37 AM
