1990 4x4 pickup 80amp Alt fuse
Old 08-15-2010, 03:43 PM
Dale813's Avatar
Question 1990 4x4 pickup 80amp Alt fuse
how to get the old fuse out ? it doesn't seem to just come out like other fuses. and is it a big deal if I jerry rig the fuse with a piece of soder so I can get to work tomorrow ? I'll pick up a fuse from Toyota tomorrw. mainly having trouble removing it.
Old 08-15-2010, 05:29 PM
myyota's Avatar
The fuse is bolted in, you can`t just pull it out. Look at the fuse holder it snaps into the fuse box, with a flat blade screw driver push the plastic clip over to unsnap it and pull the whole fuse holder out from the bottom of the fuse box, you will see the bolts that hold the fuse in place.
Old 08-20-2010, 04:32 AM
boxcar81's Avatar
yep...
MMA_Alex
25
04-18-2017 05:07 AM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
zd92655
07-05-2015 04:25 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 4x4 pickup 80amp Alt fuse
