Sponsored by: CARiD
1991 SR5 4x4 Binding in turns
Old Aug 3, 2010 | 08:42 AM
Gime1's Avatar
New guy to the posts, but I searched the topic...My 1991 SR5 X-tra cab is binding in hard (not all the way to the stops) turns while in 4-wheel drive. It really almost stops the truck. I bought the truck new and the binding has progressed to more than the normal scrubbing of the short wheel-based 4x4's and definitely more than the last 18 years. I took it to a "4x4 shop" here in Virginia (DC Area), but was not at all confident in their abilities to diagnose anything. Everything appears to be working correctly, but I know this is not normal. CV's were replaced 2 years ago, the alignment guys say the wheel bearings are OK...I'm a little stumped. Any thoughts? Thanks in advance.
Old Aug 3, 2010 | 08:45 AM
2DoorRunner's Avatar
Thats normal on dry or high traction ground. Now if it was on ice or in mud then something is wrong.
Old Aug 3, 2010 | 08:48 AM
3 min on google and i have found 3 different pages that ask the same question and get the same answer. Search harder next time
Old Aug 3, 2010 | 08:50 AM
dropzone's Avatar
Fossilized
Don't drive in 4wd on hard pack surfaces sucks as pavement, only use it on slippery surfaces. Should say that in the owner's manual
Old Aug 3, 2010 | 09:13 AM
aa1911's Avatar
ditto...
mine pops up front pretty nice in 2wd in tight slow turns; also normal (my 93 4runner)
a little off topic:
energy suspension makes really nice bushings, it will require a realignment after messing with the control arms to install the new rubber pieces but quiets things down and makes for a slightly smoother ride. mine were only 10 years old and they were almost shot all around.
after installing on my tacoma, will using what I can on my runner; won't stop your 4wd/hard surface hop 'cause that's how it works but will make for a better ride/handling!
a bit off topic, just excited to finally get them on the truck....
Old Aug 3, 2010 | 09:17 AM
blake.nemitz's Avatar
stumped on this one, looked at idler arm bushings, and what tires are you running
Old Aug 9, 2010 | 08:24 PM
Ron Helmuth's Avatar
2doorRunner- this is newbie tech and we don't bash over here whatsoever is that not correct? post 2 was fine and explained well-post 3 reeks of a bash yes?
Poster has obviously had some experience with 4 wheeling-18 years mentioned- and gives no indication he is simply describing dry surface binding.
I am also curious to learn more about what is going on.
Old Aug 9, 2010 | 08:44 PM
Then maybe you should search too!
Old Aug 9, 2010 | 09:01 PM
85gijunk4x4's Avatar
hehehe lol
i cant really ghink of anything, maybe its your u joints??? (lol, im clueless so im kinda just throwing stuff out there so please dont bash on me this is the newbie section)
or ring gear/pinion misalignment???
Old Aug 9, 2010 | 09:55 PM
Matt4Running's Avatar
My 90 binds in 4x4 on less than super slippery road conditions.This is a normal occurence.Whats the question again?
Old Aug 9, 2010 | 10:52 PM
91_TOYOTA_4x4's Avatar
sounds normal too me? i have tried to turn on pavement in 4low and all it does is fight its self, take it out of 4wd and its all fine. like most have said, shouldn't be in 4wd on high traction area's. but you said you have owned the truck since day one and its getting worse? now thats odd lol. idk but maybe your steering stops need to be adjusted? bigger tires? bad cv angles? other than that i have no idea lol i wouldnt worry too much
Old Aug 10, 2010 | 12:58 AM
vital22re's Avatar
totally a bro
keep it on topic guys and play nice. A lack of searching before starting a thread is against the rules, newb or not.
Old Aug 10, 2010 | 03:10 AM
new tires maybe have more grip, and on a warm day and hot asphalt they will grip something fierce when in 4wd on the pavement, it will buck hard. the only other thing i can think of is you might have play in your suspension or steering when the wheels are turned causing them to wander a hair when cranked and trying to cut a tight circle might bind things up more than normal. interested to see what comes of this
Old Sep 22, 2010 | 12:55 PM
93yotaSR5's Avatar
mine bind up in 4wd on high friction surfaces also. this is normal.
Old Sep 22, 2010 | 02:58 PM
brian2sun's Avatar
That's how I check that the 4x4 is working properly! No binding on dry pavement = broken.
Old Sep 22, 2010 | 03:09 PM
xxxtreme22r's Avatar
with my luck I try this and they would be broken lmao.
Old Sep 22, 2010 | 03:22 PM
93yotaSR5's Avatar
hahah maybe my hubs were messed up all along cause i never had binding while on high friction terrain until a few days ago after i regreased my hubs. guess im good to go?!
MO transplant
Apr 23, 2023 11:58 AM
Colington
Mar 8, 2020 09:51 AM
smiley52
Jul 11, 2015 05:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
zd92655
Jul 5, 2015 04:25 PM
