Sponsored by: CARiD
temp gauge spiking
Old Aug 5, 2010 | 11:09 AM
breaux's Avatar
temp gauge spiking
i have an 87 22re engine new short block and rebuilt head. about 15000 miles on the new engine. radiator is a 3 stack and about a year old. i took off the old fan and replaced it with a electronic fan. was running fine for 4 months then my temp gauge started to spike from the normal temp, which is just below half, up to just under the red. then it will slowly drop back down. this happens on hills at high speeds and then again the other day going down hill. driving around town is fine. i have replaced the water pump, and the thermostat. flushed the radiator and burped it at least 5 times. any ideas?
Old Aug 5, 2010 | 11:11 AM
vital22re's Avatar
totally a bro
Does the fan push or pull? when does it kick in?
Old Aug 5, 2010 | 11:13 AM
breaux's Avatar
the fan pushes. the gauge still spikes even if i have the fan set on high
breaux's Avatar
pushes toward the engine
Old Aug 6, 2010 | 02:02 PM
bmxjedi's Avatar
Same thing happened with me, i tryed flushing it out and nothing.it looked super clean from the top, but i Pulled out my ac condensor and powerwashed the radiator and there was mud caked in everywhere, even after powerwashing it several times through the top and bottom. All good now!
Old Aug 6, 2010 | 03:53 PM
SoCal4Running's Avatar
The radiator is probably plugged internally.
Old Aug 10, 2010 | 05:16 PM
breaux's Avatar
thanks for the advice guy's. i'm on a trip right now but i'll try clean out the radiator when i get back and let you know how it all goes. thanks again!
Old Sep 22, 2010 | 04:24 PM
breaux's Avatar
made it back from my trip. and it seems to have fixed itself. although i'm not holding my breath. it was really hot where i live when the problum was happaning. and now it's cooler so maby that was it. although that dosent make allot of sense.
ashamsuddin
17
Jul 22, 2024 03:59 AM
Jdgarrison
Oct 1, 2015 05:22 PM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
