Sponsored by: CARiD
moving axle forward on '86 SAS'd 4runner
Old Jul 26, 2010 | 03:55 PM
jmiller09's Avatar
i have the 6" all pro leaf spring up front.
i just recently took the 3" body lift off (thank God) but now my 37's rub badly on the inner fenders/wheel well.
I've cut and chopped and slammed them back more and more but it's looking like if i take it back any farther they're just going to hit the body mounts
i was wondering if its possible to turn the leaf springs around..?
from eye to center pin on the front is 25 1/2
from eye to center pin on the rear is 22 1/2
so if i turn them (if it's possible) it'll push the axle forward 3"
any input please? thanks!
Old Jul 28, 2010 | 12:09 PM
Volcom's Avatar
You might have your springs on backwards like you said. It appears that the military wrapped spring is in the back. Do you have a pic of the front of the springs & the spring hanger? You shouldn't be rubbing that bad with a 6" spring & some firewall trimming on 37's. I'm running 39.5"s, a 4" spring and tubbed firewall and don't come close to rubbing.
Old Jul 28, 2010 | 12:27 PM
4Crawler's Avatar
Yep, springs on backwards. The 22.5" length should be up front:
- http://4x4spot.com/misc__spring_information.htm
Old Aug 1, 2010 | 09:17 AM
jmiller09's Avatar
if i was to turn the springs around would i have to worry about moving shock hoops and gear box forward?
won't pitman arm just pivot and be okay? or am i wrong
anything else?
Old Aug 1, 2010 | 09:21 AM
waskillywabbit's Avatar
Flip the springs around and check. You should be fine.
You might also consider tubbing the firewall.
http://www.wabfab.org/html/projects/1985/body/ft/ft.htm
Old Aug 1, 2010 | 09:36 AM
BigBluePile's Avatar
Cool!
Old Aug 1, 2010 | 10:13 AM
muddpigg's Avatar
http://board.marlincrawler.com/index.php?topic=62417.0
This is how to do the clearance like wabbit did. My buddy runs 37 boggers with a set of tired 5" allpro springs he pushed the front hanger forward to get the clearance had to move PS box forward. Don't know about the lift spring backwards thing.
Old Aug 17, 2010 | 01:47 PM
jmiller09's Avatar
i ended up turning the springs around the correct way.
no more rubbing!
Old Aug 17, 2010 | 01:51 PM
camo31_10.50's Avatar
lol how the heck did you install the springs backwards? lol
ya shoulda installed em....stared at it for a min...looked at other sas rigs...and been like "somethin is wrong" lol
Old Aug 17, 2010 | 06:28 PM
jmiller09's Avatar
i would have done just that! problem is... i didn't do the SAS lol
Old Aug 17, 2010 | 07:55 PM
myyota's Avatar
I have 5'' All Pro springs on my 86 4Runner and ive never had a problem with it hitting the inner fender.
Old Aug 17, 2010 | 10:30 PM
jmiller09's Avatar
the springs were on backwards. problem solved. thanks guys!
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
tpd143
Jul 7, 2015 09:06 AM
ItsJustD
Jul 7, 2015 07:49 AM
karbin
Jul 5, 2015 11:37 PM
