Sponsored by: CARiD
Swamped Toyota
Old Aug 11, 2010 | 04:26 PM
Mopar18's Avatar
Swamped Toyota
I went through a mud hole swamped my 1989 toyota pickup 3.0 5 speed. I got water in my cylinders. I got all the water out and put new plugs in. It will run but will not stay running. If anyone has any ideas i would appretiate it. thank you
Old Aug 11, 2010 | 04:41 PM
Teuf's Avatar
Did you check you air and fuel intakes, cap n rotor?
Old Aug 11, 2010 | 05:45 PM
rattlewagon's Avatar
Check your oil. change if water is in there.
Old Aug 11, 2010 | 09:47 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Check your compression...
And I agree, snorkels are over rated...
Old Aug 11, 2010 | 09:57 PM
camo31_10.50's Avatar
change your oil.....
after that..check the distributor.
after that..might wanna dry out your air filter....
Old Aug 11, 2010 | 10:10 PM
MaK92-4RnR's Avatar
search... tons of people have destroyed their 3.0s via water damage.
Old Aug 12, 2010 | 07:13 AM
93yotaSR5's Avatar
distributer and wet air filter came to my mind first. dry them batches out, and do the mentioned above. did you suck water into your exhaust?
Old Aug 12, 2010 | 07:42 AM
brian2sun's Avatar
Don't stop in the middle. Really though, check oil, vacuum hoses, dist., and intake like the other's have said.
Old Aug 12, 2010 | 08:07 AM
x2, both sad and pathetic...
Old Aug 12, 2010 | 08:27 AM
prerunning4x4's Avatar
Make sure when you put it all back together you have the distributor plugged back into the trucks comp system, all the plugs are good, and that you attached the breather to the intake. Just double check that you never know.
Old Aug 12, 2010 | 08:40 AM
jammer1313's Avatar
[quote=brian2sun;51523288]Don't stop in the middle.
First time I've laughed all day, thank you...
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
