Sponsored by: CARiD
Throttle doesnt always respond.
Old Aug 17, 2010 | 07:27 PM
95blackToy's Avatar
At times only in first gear, i will get going but sometimes after im already moving i push the pedal amore and nothing happens, I push further still nothing then eventually after i push it far enough it will lurch and the RPMs will shoot way up to match the throttle.
Bad TPS? I took it off a while back and tested and adjusted it. All was fine. Had the same problem even before i fooled with the TPS. Anything else able to cause this?
EDIT: Its a 3.0.
Old Aug 17, 2010 | 07:45 PM
myyota's Avatar
Pull the throttle body and give it a good cleaning, then check and adjust (or replace) the TPS and see what happens.
Old Aug 17, 2010 | 08:02 PM
95blackToy's Avatar
Alright il have to wait on the TPS though 80 bucks for a after market one is enough to make me live with it for a while, Not like i haven't been
Thanks dude. Been kinda curios with this for a while.
Old Aug 18, 2010 | 07:57 AM
jlshaff9's Avatar
i've got issues w/ my auto trying to start out in 2nd gear. adjusting the top throttle/tranny cable resolved the issue. JCIII started a thread detailing the adjustment, but it begins with throttle cable adjustment, which may resolve ur issue anyway.
i'll try to find link and attach
Old Aug 18, 2010 | 07:58 AM
jlshaff9's Avatar
just read your signature to see that ur not an auto tranny. sorry for irrelevant post
Old Aug 18, 2010 | 08:03 AM
95blackToy's Avatar
thats alright Thanks anyway though.
Old Aug 20, 2010 | 04:14 AM
boxcar81's Avatar
cleaning i bet will fix my cuz had the same issue
Old Aug 20, 2010 | 07:39 AM
95blackToy's Avatar
It only sometimes does it. I ran a can of sea foam through the upper hose into the throttle body and stuff. So far it seems better. But il see in the next few days of driving.
Old Aug 20, 2010 | 10:44 AM
oldskoolstang's Avatar
It's a cable operated throttle on that truck, so just a good cleaning should fix it.....I doubt that it is the TPS, but you could always check the voltage at the TPS and see if it is within spec
Old Aug 20, 2010 | 11:50 AM
95blackToy's Avatar
yeah it seemed fine. I adjusted it a few weeks ago. Thanks guys. And the throttle body is spotless. Il see how it does this weekend while at the deer lease.
some drunk guy
Aug 3, 2021 06:09 PM
the_supernerd
Oct 1, 2015 09:20 PM
shredder4286
Oct 1, 2015 01:09 PM
Sam hain
19
Sep 30, 2015 08:25 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
