TRD axle swap into 82 pickup
Is it possible to swap the whole rear end trd axle into an 82 pickup? i know the width of it is longer by about 5 inch or so but just wondering because i got a buddy who is welling to get ride of his for 200.
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
FWIW, If it was MT you stand a good chance of the gears being the same...
AT and forget it!
Look for a color dot on the pinion... Or get the code off the TRD, and the one off yours and make sure they match.
http://forum.ih8mud.com/79-95-toyota...ml#post2089610
I can feel the questions coming...
AT and forget it!
you better get that as a selectable is hands down the best traction, and a Aussy is $150 easy...
Go see inchworm to get the stuff needed to lock it up with.
http://www.inchwormgear.com/store/index.php?cPath=25_62
Gravel Maker
RuffStuff
Jul 6, 2015 07:43 PM
nosliw
12
Sep 16, 2002 03:20 AM
