Sponsored by: CARiD
Rear turn signal not working.
Old Jul 31, 2010 | 11:07 AM
DavezFever's Avatar
So my left turn signal is blinking twice as fast as my right one and so i checked both the front and back on the left side and the rear one is out. I opened it up and both bulbs don't look burned out. The fuse under the driver kick panel for turn signal is fine also. Should i check the front left turn signal even though it appears to be working or change the rear turn signal bulb even though it looks fine? Any other suggestions?
Old Jul 31, 2010 | 11:09 AM
2DoorRunner's Avatar
Change the bulb thats not working
Old Jul 31, 2010 | 11:15 AM
xxxtreme22r's Avatar
instead of buying a bulb first try putting the bulb in question into the other side and see if that side starts blinking faster. If it does then buy a bulb. if not then you got another issue.
Old Jul 31, 2010 | 12:18 PM
DavezFever's Avatar
The right bulb worked when i switched them. Good call. Just bought a new bulb at napa and everything's good to go. Brain is functioning a little slow this morning. Thanks guys.
Jun 1, 2021 01:51 PM
Doug4320
Mar 24, 2018 10:11 PM
KBar
Jul 13, 2015 06:01 PM
88yodabasket
Jul 13, 2015 01:32 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
