Sponsored by: CARiD
Turbo gears in a 22RE ???
Old Jul 29, 2010 | 05:19 PM
mldave's Avatar
This 86 4x4 2.4RE truck is supposed to have turbo gears as the previous engine was turbo.Any benefits from this set up as opposed to whatever gearing is standard on this rig?any MPG difference?Don't know nothing about any of this stuff.
Old Jul 29, 2010 | 05:26 PM
xxxtreme22r's Avatar
gearing will be the same unless your talking auto (4:30) versus manual (4:10), however, the differentials on the turbo and v6 (same differentials) are a little stronger.
Old Jul 29, 2010 | 05:33 PM
brian2sun's Avatar
I could be wrong, but I think you're talking about the rear diff which is called the "V6/Turbo 8" diff". That doesn't determine the gear ratio, that's only the housing. This 8" diff was used for 4 cyl turbo and V6 pickups from '86-95 (as well as 4runners up till '02).
Old Jul 29, 2010 | 06:02 PM
mldave's Avatar
Yeah it was a 4 cyl turbo,5 speed.
Old Jul 30, 2010 | 02:45 AM
85TurboRunner's Avatar
I had an '86 turbo truck with an auto and it had 4:10's.
Old Jul 30, 2010 | 02:59 AM
malteserunner's Avatar
I had an 86 turbo/5 speed with 3.90's. The MPG's will differ depending on the type of driving you do. Since you are in the mountains, you probably would benefit from lower gearing, but as previously stated, we can't tell which gears you have based solely on your truck being a turbo model. One thing to consider however, is that if you have the original turbo transmission (R151F), then it is far superior in strength compared to the normal 4 cyl transmission.
Enjoy your Yota!
Old Aug 2, 2010 | 12:13 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
If it's a 4WD, get that 5 speed...
If it's 2WD, there's nothing special about it...
in a 2WD or 4WD?
Old Aug 2, 2010 | 09:02 PM
Originally Posted by tried4x2signN
in a 2WD or 4WD?
4WD
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
