Sponsored by: CARiD
removing the side skirts on removable top!
Old Aug 12, 2010 | 11:55 AM
kidznplay's Avatar
Hello..I have One almost perfect hard top from an 87 4runner, and I want to replace that rusty side skirt under the window.. how do you remove them ?? do you have to drill holes to get at the screws in there??? thanks for the help
Old Aug 12, 2010 | 12:23 PM
RBX's Avatar
RBX
Do you mean the L-trim under the sliding windows?
https://www.yotatech.com/forums/f116...cement-190299/
Old Aug 12, 2010 | 02:12 PM
kidznplay's Avatar
Yes the L trim..I have new one's. any idea how those come off??
Old Aug 12, 2010 | 02:15 PM
4Crawler's Avatar
The Factory Service Manual (FSM) has a detailed procedure for doing so.
Old Aug 12, 2010 | 02:19 PM
kidznplay's Avatar
ok ..cool thanks
Old Aug 12, 2010 | 03:03 PM
myyota's Avatar
The windows are held in place with butyl sealant tape, to remove the windows you need to remove the black trim on the inside from around the window, the take a putty knife and work it around between the window and the top carefully prying as you go to work the window loose, then from the outside you can pull the window free. You will need to get some butyl sealant tape to reinstall the window properly.
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
ItsJustD
Jul 7, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
