Sponsored by: CARiD
No dash lights???
Old Jul 25, 2010 | 05:47 AM
mldave's Avatar
No dash lights???
On my 86 Toyota truck..started up this morning and no dash lights.Headlights ,turn signals,flashers,radio lights all work,but no light over the speedometer panel.Fuse,bulb,wire??? what's the fix and estimated time to do it?..thanks.
Old Jul 25, 2010 | 06:03 AM
1990yota-pickup's Avatar
read you hyanes mannual on how to pull the speedo cluster
there should be 2 bulbs that are in there that are burn out.. should be under 6 bucks at any parts store..
all the bulbs in the cluster are the same so you can pretty much pull one out and try a in different location
Old Jul 25, 2010 | 06:12 AM
mldave's Avatar
Yeah 90 yota,the fellow that fixed up this truck changed the speedometer itself so maybe he shorted something out?
Old Jul 25, 2010 | 07:35 AM
oh, well check to see.. if a fuse is burnt out.. first then it will be a dead give away if you got a bigger problem then a just a burn out bulb...
by the way bulbs will burn out more often if they get more amprage then they need..
Old Jul 25, 2010 | 02:03 PM
mldave's Avatar
Which fuse and what amp is it?There are two boxes,one in the engine compartment,other drivers side kick panel under the door.Also does that fuse also do the cabin courtesy light?
Old Jul 26, 2010 | 02:40 PM
well your dome light is connected to your door buzzer switch,, will make nosie if your door is open..
pull your dash and just check so see if you just burnt a buld it should take no longer than a hour, taking it all apart...
your bulbs, can be bought at any parts store..
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
