Sponsored by: CARiD
Check engine light question
Old Jul 29, 2010 | 08:08 PM
1987yota's Avatar
Hi all, I'm new here. I did a search and didn't find anything helpful so here goes...I have a 1990 4runner with the 22RE engine and after removing and cleaning the battery terminals the "Engine" light came on. I have a Haynes manual and it says to jump the TE and T1 ports in the diagnostic block and count the flashes, but the light stays on steady. I then removed the EFI relay to hopefully reset the light as per the manuals instructions but the light is still on steady. The truck runs fine. Any thoughts why the light is on and/or won't go out? Thanks in advance guys.
Old Aug 3, 2010 | 05:36 AM
colsoncj's Avatar
I thought it was the T1 and E1 terminals.... may need to double check and make sure you're jumpering the correct terminals... when you do, with the key in and turned to the run position, without it running, it should flash.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
