View Full Version : Newbie Tech Section
- Doing Clutch help with drive shaft!
- New Guy with Chevy to Toyota Swap questions in a 2nd gen 4Runner
- 94 Toyota V6 questions?
- Swapped 1993 transfer/tranny sensor Problems
- rust by windshield
- Trans swap question
- Can I delete the resonator?
- Rebuild old 3.4 or go 1UZ
- Clutch has about had it.
- Threaded holes in front crossmember?
- Reverse dissappeared, hard shift for months
- Ring and Pinion parts list questions before I purchase my parts, tire advice too.
- 96 taco lift question
- Help
- LSPV on truck used for hauling/towing-Keep it or pitch it?
- Getting ready to ZUK the pickup-how much lift?
- Some advice would help big time!! 1991 4x4 hilux flip and needs help
- New guy
- Is this a good product?
- truck weight
- Ignition cuts out
- Wiring from sending unit to gauge?
- Where does this bracket go?
- Why clean throttle body??
- Toyota 1 Ton dually Flat beds
- Quick belt question
- Timing on a 1994 4runner 3.0 and any important info welcome
- L50 Transmission Issue
- Paint logistics/questions
- 87 runner cant pass DEQ
- power source
- Bulb Changes
- alt adj ???Oil holder???
- input on my 92 lift ideas
- 15x6 Steelies W/ IFS? Spacers/Backspacing?
- Im not a newbie but section is appropriate for the question
- Wish I could By-Pass This
- What is this?
- Arkansas 4runner, running rich?
- i need help with my 22re motor
- New guy with loads of questions
- Will this axle swap?
- 87 4ruuner temp gauge problem
- What Front shocks should I get?
- 93 pickup in need of modifications
- Need help on toyota
- Newbie
- Shocks and Suspension - 1999 4runner SR5
- 91 22re turbo possibly?
- New Here
- Engnbldr.com....good or bad?
- Loss of power on take off and going down the highway
- 1984 22r toyota 4x4 pick up alternator plug wiring HELP!
- Foward Shift Modification Question
- Newb with No Questions??????????
- 93 Hilux lift questions.
- Tundra 17" wheel help.....
- Updating a 1992 4X4 Deluxe Pickup SWB's Suspension
- 88 sr5 3.0 to 3.4 swap?????
- Need Help making a decision about my Toyota Truck
- 87 4runner fuel door
- need help choosing motor swap1?!?
- shortbed
- 1994 Toyota Pickup 327.000 miles
- easiest way to lift a 1990 4runner 4x4?
- Recomended Timing Chain Kit
- Steelseal pros-cons??
- can I get a aftermarket tank?
- What does ADD stand for?
- What to do???...
- Receiving hitch ?
- Just installed OME torsion bars, question about rear mount
- Chevy 63 springs question
- What is the cheapest place to buy a 3vze for 88 pickup
- solid axle swap?
- 22r feels hot, but freshly started cold
- Timing belt issues no power sputtering
- 94 22RE misfire/sputter
- 1980 20R head on 1983\84 22R Block?
- EFI computer sources
- 87 p/u 22re 4wd 5 speed trans ?
- Lifting My 1992 Yota Pickup
- 2wd to 4wd conversion
- 32X11.5s on 10in wide wheels, possible?
- Replacing 22re with 20r. Feasible, practical?
- Chrome removal?
- 86 22re iacv check procedure?
- Winding noise in transmission.
- Need a lift
- anyone have any info on an A340H transmission
- eliminating steering shaft slip joint
- Need help removing bolt from gas tank flange
- Someone help me identify problem.
- AC belt/idler pulley 22r
- Dually finally
- fuel leak
- I need A Lift
- 2011 Tundra paint
- windshield question.
- Can i put a 2nd gen cab on a 3rd gen truck?
- 22RE Operating Temperature Questions.
- need help on steering problem
- 87 4Runner misfiring even with new engine
- Difference between windows?
- 1992 6Cyl 4x4 as daily Driver
- 3vze Dash Pot Cracked
- Bogging out in 3rd!?!?
- Rear axle
- Idle screw and belt squeal
- dash lights 04 tacoma v6 at
- 95 forerunner V6 runs fine on LPG but idles rough on ulp
- Help needed automatic transmission oil
- will an 83 tranny fit in my 82 ????
- 89 pickup with chevy heartbeat
- Brush Guard Question
- 94-22re head rebuild and major tune up questons
- Question about axle diagram
- DIY tint
- Gas tank suction. A LOT
- Drop bracket and Ball Joint spacer pics.
- Coolant leak causing idle problems?
- 86 toyota 4 runner alternator relay
- Bj spacer
- Bilstein Warranty?
- how high can i go?
- Painting my hubs
- back spacing SOO CONFUSING !!!
- pull a leave and add a shackle better travel
- chevy rims on a tacoma,wont fit!!!
- 86 pickup 4x4 solid axle question???
- Heim joints? ????
- head gaskets
- Actual size of B.F. Goodrich Mud Terrain KM2 265/75R 16
- 3rd gen gauge cluster
- Best Battery???Please help!
- Getting a lux soon just need to no some stuff
- gauge cluster help
- auxilliary air valve
- Jeggs lift blocks?
- Burnt oil around exhaust valves
- need advice on setting up my lift
- 94 toyota 4runner improvments
- Manual Tranny Problems
- check connector pic?
- 3" suspension lift on 83' - heavy vibration in 4 Wheel drive
- 22r Surge At cruising speed
- transmission section?
- Front drive shaft - '89 will fit a '93?
- 22R/20R cam choice
- 91 toyota 4runner 3.0 bad hesitation, feels like its missing help please
- Windshield wipers skipping?????
- Converting truck to an off road trailer.
- L43 Shifter/shaft connect Bolt? I NEED ONE
- What have I gotten myself into, I can't keep her running!
- Help diagnose vibration, please!
- 88 standard cab's been sitting, want to get it back into form
- pic of 85 efi motor top and big yellow screw vacuum port?
- MY 95 tacoma wont shift into reverse when cold
- 1991 4runner 22re, saying hey.
- Toyota chevy axle swap what front springs to use?
- miss fire on a 92 4-runner
- Solid axle pull
- 1990 4runner- i need to know what exactly i need for an sas!
- antiseize on spark plugs?
- Removing front drive shaft....
- driving lights
- Differential Gearing with W55
- problem after shifting
- dual diaphram booster
- New headlight assembly questions(1st Gen Truck)
- how to adjust a holley fuel regulator
- Will 99 tacoma lugs work on a 94 landcruiser?
- no reverse
- 1991 4Runner SR5 - Restoration HELP!
- VSC trac light on 4WD light won't come on or engage
- 92 4runner running rough
- Bumper Coating
- What Oil?
- routing of longer brake lines
- Quick Question about gears
- 87 Pickup SAS Questions
- how much travel should the clutch slave rod have?
- 88 4runner body trim
- 1990 pickup brake lines
- 1994 4runner bull bar
- 94 Runner Skid Plate
- 1990 3.0 (Auto) 4x4 4runner TRANNY ISSUES!
- Motor swap for 99 Tacoma
- Thanks for all of the info!
- Birfield wont go in
- My first yoyo!!!!
- 86 4runner sputter
- 04 Taco gearing?
- Flex Help
- 1988 4runner - what is this outlet?
- Did anyone hear of this ? Supercharger Kit turbo chip performance
- 1980 Toyota 4X4 power steering problems
- How to mate a forward shift transfer to a r150f
- led strip lights
- water leak under the coolent temp senser?
- 88 SR5 larger fuel tank
- IFs pickup ift. Superlift or Procomp
- More high output alternator info and ?
- how to replace a 984runner fuel press reg.
- Quick ?: control arm years of compatibility
- Truck sputters/fuel delivery issues?
- Where do I buy the Downey HD Coil kit?4runner LC spring conversion?
- 1980 toyota 4x4 carb problem
- oils.. differential and manual transmission
- i dont want to die on the freeway; help!
- 1989 toyota pickup
- Struts / Shocks question(s)
- 99 4runner battery & starter problem
- holley regulator and mr gasket fp gauge how to connect together
- Quick how-to on caliper/pad replacement....
- First 4runner, first of many questions
- Truck won't start
- Running Hot on the Interstate
- Help with a FOB remote
- what size bolt for t case / 5 speed tranny check/fill
- IFS hubs for 85 Solid Axle?
- 1995 22N? Over Heating
- 86 4Runner starts then sputters out
- 9422re oil in anti freeze?
- Well it aint got glow plugs i dont know about it!
- Well It aint got glow plugs so i know nothing bout it!
- Please help me figure out the wiring from the VR to the alternator.
- 87 four runner transfer case not engaging
- Spare tire removal - seized?
- crazy air-fuel ratio
- 3.0 Knock Sensor...STUMPED!!
- Solid-axle alignment, truck pulls to the left
- leaking Transfer Case Cooler -
- Suspension
- IFS hub on SA question
- driveline vibration 94 4X4 pickup
- Hood fluttering
- "Bench Bleed" questions...
- 89 Toyota truck 4x4 - Gas Problem
- 86-95 Truck Pre-purchase inspection
- 87 extended cab shortbed what camper shell?
- new shocks
- weber install use a gasket sealer?
- Rear axle assembly replace and advice.
- Ignition key lock on a 79
- o2 sensor connection location?
- rebuilt 22re won't run/start
- exhaust manifold is warped now what?
- LSPV and me - what do I need to know here??
- Engine swap i have a 1980 an have a wrecked 1995 toyota tacoma both are 4 cylinders
