Sponsored by: CARiD
Need help on toyota
Old Feb 16, 2012 | 03:10 PM
toyota 2015's Avatar
Red face Need help on toyota
Hey i have a 1988 toyota 22re turbo pickup and I was wondering if I could put that in a 1992 toyota in place of a 22re
THANKS FOR THE HELP:wabbit2:
Old Feb 16, 2012 | 03:58 PM
bjlambert's Avatar
If they're both 22re why not just put the turbo on the other? if they're both 22re they should both be the same
Old Feb 16, 2012 | 05:39 PM
DeathCougar's Avatar
This is the kind of misguided advice that gets people in trouble.
22RE and 22RTE engines are NOT the same. They don't even have the same compression ratios
Old Feb 16, 2012 | 05:42 PM
93Xtra-Cab's Avatar
The 22ret has lower compression for turbo boost and a different cylinder head design (although they are interchangeable). They also have oil lines coming from the back of the block and an oil return in the center of the left side. The 22re has these cast in the block, just not drilled or tapped. Also, trucks with the 22ret have different radiators.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
