Sponsored by: CARiD
Solid-axle alignment, truck pulls to the left
Old Jan 11, 2012 | 10:34 AM
moroza's Avatar
You can adjust toe by turning the tierod ends, and caster with shims (?) between the spring and axle. But there's no adjustment for camber, right? Other than damaged hardware causing mismatched camber, what could cause a solid-axle 1st-gen to pull to the left at all times? I don't think the brakes are dragging but I'm not sure; it pulls maybe a little harder when braking, not by much.
Old Jan 11, 2012 | 10:42 AM
waskillywabbit's Avatar
Looked at the FSM yet?
:wabbit2:
Old Feb 11, 2012 | 06:10 PM
moroza's Avatar
Yep (the 85 one; I assume the section on axles applies to a 1st-gen). As far as I can tell, there is no camber adjustment except bending the axle housing.
I've never worked with solid-axle vehicles before; is it possible that a slightly bent frame would cause mismatched camber, or would only things within the axle itself (trunion bearings, whole thing bent) cause that?
Ichneumon
Sep 27, 2015 04:21 PM
miceal383
Jun 29, 2015 12:27 AM
AustinTaco
Jun 21, 2015 09:54 AM
NerfHerder-97SR5-
7
Jul 12, 2002 03:42 AM
Hermes
7
Jul 8, 2002 03:45 PM
