Sponsored by: CARiD
Foward Shift Modification Question
Old Feb 14, 2012 | 08:01 PM
94yota111's Avatar
Is it possible to extend the shift rod that connects to the shift fork on a forward shift transfer case to accomidate a V6 adapter plate and keep the transfer shift in the original position on a R150F transmission.
Old Feb 15, 2012 | 03:16 AM
rattlewagon's Avatar
You must use a top shifter when adapting a gear drive transfer case to a v6.
Old Feb 15, 2012 | 06:48 AM
94yota111's Avatar
Can anyone explain to me why its a must to convert it to topshift. I understand the shift rail will be to short with the V6 adapter plate i just dont understand why the shift rail cant be lengthend since the transmission has the provision for a foward shift transfer case shifter.
Old Feb 15, 2012 | 07:35 AM
The shift rails interfere with the adapter plate.
http://www.pirate4x4.com/forum/showthread.php?p=2917582
Your shifter should stay close to the original spot with a top shift transfer.
Edit: Been doing some googling... Seems you can avoid the adapter by getting a r151F (good luck finding one) tail housing, and that would allow you to run a forward shift case. Maybe? Maybe some one can chime in....
Old Feb 15, 2012 | 08:02 PM
94yota111's Avatar
Thanks for the info
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
