Sponsored by: CARiD
exhaust manifold is warped now what?
Old Jan 8, 2012 | 07:07 PM
jkent's Avatar
Like the titles say my exhaust manifold is warped so I'm thinking about going the header rout. I'm a little low on my truck funds (blew it on a winch and dual bat. set up) so my budget is $200.00
my specs:
1985 Toyota 4 runner
22re
2 inch exhaust
hollowed out cat. (ford catalytic converter)
no smog requirements
After hitting the search button and my budget in mind I'm thinking this might be my option?
http://www.ebay.com/itm/OBX-Exhaust-...item2a1769bb8a
questions:
1. Is this the right one?
2. I'm assuming I will need to modify the exhaust to match up?
Collector Diameter: 2 ½ Inch. (mine exhaust pipe is 2 inches)
3. Will I have to lengthen the wire for the 02 sensor?
4. is it worth the money or should I just get another stock manifold?
5. Whats the difference between a "race" header and a "reg." header? noticed it on a few listings on ebay.
any help would be appreciated..oh and Ive worn out my button.
Old Jan 8, 2012 | 07:08 PM
Elton's Avatar
where at in oregon are you ?
Old Jan 8, 2012 | 07:09 PM
jkent's Avatar
Eugene
Old Jan 8, 2012 | 07:11 PM
Elton's Avatar
i think my friends got like a doug thorley header prob take 150 for it i could ask him about it if you want ?
Old Jan 8, 2012 | 07:14 PM
jkent's Avatar
hey that would be great! where you located?
check that! just noticed Siletz Oregon
Old Jan 8, 2012 | 07:15 PM
creswellhick's Avatar
i get a header unless u found a cheap manifold and get rid of that cat
Old Jan 8, 2012 | 07:16 PM
Elton's Avatar
like 10 mins from newport
Old Jan 8, 2012 | 07:17 PM
jkent's Avatar
Had the cat put on because it was way too loud without it..lol
Old Jan 8, 2012 | 07:27 PM
loud pssh u should of heard my truck with a purple hornie right off my header u couldnt talk to anyone or here your self think its much better now 2.5 pipe to a flowmaster knockoff which actually sounds good no cat and coming out at the end of the cab
Old Jan 19, 2012 | 09:00 AM
2Wheeler's Avatar
Last time I was installing an exhaust manifold, I took it to an automotive machinist who flattened the mating surface for me. Just took off a few thousandths and charged me $20.
Old Jan 19, 2012 | 09:06 AM
mightymouse's Avatar
either take it to the machinist (your manifold is a cast piece so i don't know how you warped it) and get it surfaced. Or just get one of these http://catalog.remflex.com/category_s/56.htm yes they do work and they are inexpensive.
Old Jan 21, 2012 | 10:33 AM
jkent's Avatar
Thanks 2wheeler and Mightymouse for the reply!
I'm not sure if its warped or not? took it off and got the straight edge to check it out.. it doesn't seem too off?? For whatever reason the damn thing wont bolt up right? either the back (firewall side) has a exhaust leak or the front has a exhaust leak. Tried a few times now with no luck. Maybe i will get a file and clean it up a bit.
Thanks for the link mightymouse! I might go this route.
Old Jan 21, 2012 | 10:37 AM
jkent's Avatar
Dang Bro! I hope your not under water!
Old Feb 15, 2012 | 03:17 PM
jkent's Avatar
thank you Mightymouse! the remflex worked great!
Old Feb 15, 2012 | 08:33 PM
Thanks for checking back and letting us know what and how it worked out for you. The remflex gaskets kick butt huh.
_Nicco_
Sep 21, 2015 03:06 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
Obmi
Sep 10, 2015 03:36 AM
idadan208
Sep 7, 2015 09:06 AM
