Sponsored by: CARiD
antiseize on spark plugs?
Old Jan 23, 2012 | 11:36 AM
shafner30's Avatar
hello
going to put new spark plugs in soon
should i put anti-seize on the threads of the spark plug or not?
Old Jan 23, 2012 | 11:46 AM
snobdds's Avatar
Yes
Close thread.
Old Jan 23, 2012 | 02:08 PM
SoCal4Running's Avatar
100% Absolutely Positively
Old Jan 23, 2012 | 02:21 PM
nightstalker's Avatar
fo sho
Old Jan 23, 2012 | 03:03 PM
rhill's Avatar
Not absolutely necessary, but often recommended to prevent the plugs seizing (getting stuck) or possibly breaking off during removal.
Old Jan 23, 2012 | 03:16 PM
swampfox's Avatar
Just make sure to put a light coat,I put a little to much and it wicked onto the plug tip fouling the plug.
Old Jan 26, 2012 | 04:59 AM
Bassmastry101's Avatar
Personally I don't use it. Don't torque them down..they don't hold the head on. and Don't use too much or else the plugs won't make a good ground and you will get misfires.
Old Jan 26, 2012 | 06:37 AM
MudHippy's Avatar
It's not a matter of using anti-seize or not. It's which anti-seize do you use.
Answer: Copper
Permatex® Copper Anti-Seize Lubricant
A premium quality copper anti-seize and thread lubricant that may be used to prevent seizing, corrosion and galling where high temperature conditions exist. Contains a high percentage of micro-fine copper flakes in a semi-synthetic grease carrier and is fortified with high quality rust and corrosion inhibitors. Temperature range: -30°F to 1800°F (-34°C to 982°C). Provides good electrical conductivity. Meets Mil Spec #907E.
Suggested Applications: Spark plug threads installed in aluminum, exhaust manifold bolts, engine bolts, oxygen sensors, knock sensors, thermostat housing bolts, fuel filter fittings, and battery cable connections
But I've used the regular stuff(aluminum + copper) for many years on spark plug threads in aluminum heads and never had any issues. So I'll use either, but preferably the copper.
http://permatex.com/products/Automot...lubricants.htm
Old Feb 6, 2012 | 01:34 PM
scarey's Avatar
yes, and the Permatex products are A+++
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
