Sponsored by: CARiD
94 22RE misfire/sputter
Old Feb 10, 2012 | 02:45 PM
maxcaven's Avatar
Hey guys I have 94 pickup, when I get going up to speed in say, 3rd, 4th and 5th, as soon as I give it any real amount of gas, I'll have a misfire. That leads me to believe its fuel related. I have newer plugs/wires/cap in the truck and it seems to idle fine.
My buddy thinks its a fuel filter, and I'm wondering if that could be it? Or does anyone have any other ideas at what it could be?
Thanks for any help/advice.
Old Feb 10, 2012 | 02:47 PM
maxcaven's Avatar
Also, apologies for the terrible grammar. Damn phone makes it tough.
Old Feb 10, 2012 | 04:42 PM
James Woods's Avatar
Check timing, did you replace the rotor or just the cap? Is the check engine light coming on? Might help to narrow it down to a certain cylinder or pair of cylinders if it has code.
Old Feb 10, 2012 | 05:05 PM
maxcaven's Avatar
The truck has been running fine for a year or so after I did the tune up. But it was just the cap, if I recall correctly. No check engine light either.
Old Feb 10, 2012 | 05:08 PM
TylerH's Avatar
Im having the same problem. I let off the gas then then give it gas again and it cuts out and sputters and then goes away. I was thinking it was because i have a bad exhaust leak at the front flange and maybe theres air getting in and making the O2 not read correctly.
Old Feb 10, 2012 | 05:42 PM
maxcaven's Avatar
Good idea actually, I do have an exhaust leak that needs to get taken care of regardlessly, maybe that's it.
Old Feb 10, 2012 | 05:46 PM
TylerH's Avatar
How bad is it. And where is the leak at. Mines at the flange and its pretty bad.
Old Feb 11, 2012 | 09:12 AM
maxcaven's Avatar
Not super bad, at least I don't think. The leak is up front somewhere, haven't pin pointed it yet. I have an appointment with the exhaust shop on monday.
I forgot to menton that I also have a leaky gas tank, is there any chance I could be loosing fuel pressure and that's causing the issue? The tank leaked for quite a while before this happened, that's why I never even thought of it. Regardless I have a new take to swap in, just waiting for it to be warmer than -4 outside.
Also, my buddy thinks it might be out of time. He's got the gun and we're going to try that too.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
