Sponsored by: CARiD
1989 toyota pickup
Old Jan 14, 2012 | 09:38 AM
t-rav's Avatar
1989 toyota pickup
hello everyone, i have a quick question on my toyota.. lately i have been driving and my truck pulls to the left pretty hard and i have no idea what would be causing it... my alignment is fine, my bearings and brakes are good... so im not sure what else it could be... any ideas? thanks again
Old Jan 14, 2012 | 02:35 PM
swampfox's Avatar
Low air pressure or maybe a brake line that is collapsing inside and causeing the caliper to release slowly.
Old Jan 18, 2012 | 06:38 PM
rattlewagon's Avatar
Balljoint?
Old Jan 19, 2012 | 03:56 AM
93Xtra-Cab's Avatar
Are you sure your brakes are fine? It sounds like your caliper might be seized up because that is what happened to mine. Does it pull all the time or is it sometimes when you let off the brakes?
Old Jan 19, 2012 | 09:08 AM
t-rav's Avatar
i have checked all my tires which are fine, my balljoints are also fine, ive yet to check my caliper yet, but i think ill check that next... it pulls all the time and when i use my brakes it seems to pull alot harder... so im still trying to figure it all out.. thanks everyone again for the info
Old Jan 19, 2012 | 11:41 AM
skypilot's Avatar
Here's personal experience.
Ball joints wear, they may look good but they move around under pressure. How do you know they are good? Mine were bad and the truck jumped around too much on rough surfaces. All four got replaced and it started tracking through the potholes rather than around them.
Tie rod ends are easy. Have a friend rock the steering wheel back and forth and feel for movement in all the joints, that is not correct. Watch both pittman arms for up & down movement. Does the steering box input match the output? Have said friend drive over boards or logs or something and watch for that "wrong" movement from the mechanism.
Brake calipers seize, I've seen it so often its like the sun rising sometimes. Check for uneven pad wear, if its more than a little replace it.
Trucks don't suddenly start pulling to one side for no reason, something is worn out; or you bent it on a rock or pothole.
The truck will tell you whats wrong, you just have to see the message.
You didn't say how many miles are on it, but anything over 100k; you would not be wrong to replace the upper ball joints since they carry the weight of the truck on them due to the torsion bar suspension. YMMV
Old Jan 20, 2012 | 09:51 AM
t-rav's Avatar
ill be looking into all of this after work today, ask for the ball joints i just took my truck to les schwab and they said they were fine... but then again they probably didnt really check... My front axle is off i believe 1997 land cruiser... its a straight axle.. thanks again
Old Jan 20, 2012 | 10:59 AM
Well thats a horse of a different color..... Should have mentioned that in the first post. Got pics?
Could the axle be bent? Leafs or links? Hows your steering hooked up?
Old Jan 20, 2012 | 12:59 PM
meisentones's Avatar
Are the right sized tires bigger than the left side?...
LMAO...
Sorry, couldn't help it.
Old Jan 20, 2012 | 02:31 PM
t-rav's Avatar
all i have at the moment... but ill get a few more
Attached Thumbnails 1989 toyota pickup-truck-new-3.jpg   1989 toyota pickup-truck-new-2.jpg
Old Jan 20, 2012 | 03:22 PM
That looks like a 85 mini truck axle with a TG truss on it, not a LC axle.
I would check your trunnion bearings.
Old Jan 20, 2012 | 03:26 PM
t-rav's Avatar
ill check that after work... but i wasnt even sure bout the axle, but when i had to get some pieces replaced on my axle, the guys said it was all from a 1993 - 1997 land cruiser and i believe an 85 is more tube like i would say
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
rondogracing
Jul 5, 2015 12:32 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
