Sponsored by: CARiD
Truck won't start
Old Jan 13, 2012 | 06:15 AM
ta2luvgdess's Avatar
Truck won't start
I just replaced the fuel filter and fuel pump on my 94' Toyota pickup and now it won't start. Can you help with what the problem could be?
Old Jan 13, 2012 | 06:34 AM
Bassmastry101's Avatar
In your last post you said it was a 22re correct?
Start simple, are you getting fuel at the rail?
Old Jan 13, 2012 | 07:12 AM
yes it's a 22RE engine 4 cyl. I got it started, now it sputters and won't go over 15mph when gassed it dies. Can you help?
Old Jan 13, 2012 | 07:16 AM
Tech Tim's Avatar
Sounds like a silly Q, but did you install the fuel filter the correct direction?
Old Jan 13, 2012 | 07:20 AM
yes we did. It's running but when I step on the gas it sputters and wants to die. Could it be the air flow sensor? It was doing this before we replaced everything too.
Old Jan 13, 2012 | 07:42 AM
Are you sure that you hooked everything back up correctly?
Can you give us a little more detail about what all was done or replaced. It might help narrow it down.
Old Jan 13, 2012 | 07:49 AM
So far I have replaced the water pump, fan clutch, v-belt, fuel filter and fuel pump. But it was sputtering before we replaced the filter and the pump.
Old Jan 16, 2012 | 04:11 AM
Ok, it sounds like the fuel system is good to go. Have you looked at the timing?
Old Jan 16, 2012 | 05:36 AM
clevelandsmostwanted's Avatar
try to disconnect your throttle position sensor and or mass air flow see if it changes anything
Old Jan 16, 2012 | 05:42 AM
BIGTOY88's Avatar
I would check all your sensors first. Mine was doing the same thing and I replaced the air flow sensor and I was good to go. If that doesnt do it then I would move on to the timing and make sure that it is all squared away.
Crazychris1871
Jun 27, 2016 10:38 AM
Cesarl74
Apr 23, 2016 06:07 PM
newzingo
Jun 24, 2015 01:50 PM
slider417
Jun 22, 2015 10:18 AM
Corey
Jun 10, 2002 04:23 AM
